Old 07-13-2003, 10:34 PM   #1
maxpsi
12 second civic !!!!!!!!!!!!!!!!!
New Best:
R/T .699
60ft. 1.917
330’ 5.529
1/8 8.423
mph 85.71
¼ 12.999
mph 107.56
Jim at Motorvations in Trussville, AL (plug) let me borrow his 22x8 M/T slicks. I started out with a 13.5, then a 13.3, and a 13.244. Then for the last run (one above) I dropped the tire pressure from 16psi to 12psi, changed the shiftpoint from 8000 to 7800 (I feel the need to visit my rev limiter too much), and just barely slipped the clutch at 6500rpm. Pulling that kind of 60ft. felt great. Track conditions: 90+ degrees, sticky track, and a little overcast (as if that mattered). This all on an open diff, stock driveline with exception to the CM stage 1 clutch, and stock block.
Old 07-13-2003, 10:35 PM   #2
2000Pimpinex
Super Moderator
2000Pimpinex's Avatar
Congrats man. That is an impressive number. Hope one day I can get there. Sometime really far down the road.
2008 Mustang GT
1998 Hatchback SOLD
1985 Ford Bronco XLT 5.8 351W
w/ 33X12.5X15
Old 07-13-2003, 10:45 PM   #3
Max, list your mods again, except what's mentioned above. Great job man!
Old 07-13-2003, 10:55 PM   #4
maxpsi
Sorry. I just typed this post up on Microsoft Word because I post in alot of different forums, and I forgot to add in this link for the people that don't know me well. Here ya go.....the setup is pretty correct.
http://www.auburnextremeracing.com/drivers/Scott/
Old 07-14-2003, 12:26 AM   #5
Nice work man! Was it necessary for you to convert to OBD1 ECU to use your Hondata? Nice sleeper......
Old 07-14-2003, 12:40 AM   #6
maxpsi
Thanks!
Yes, it is necessary.
Old 07-14-2003, 01:26 AM   #7
do you have alot of turbo lag? it looked that way from the dyno.
Old 07-15-2003, 10:21 AM   #8
Mushroom
Looks like a 13 second civic to me.
Old 07-27-2003, 11:35 PM   #9
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
u lucky bastard! just messin'.....good job... i'd like to have a car that gives mustangs a run for their money
RICE....is good
Old 07-28-2003, 03:19 PM   #10
get a turbo dude......
