Old 07-02-2003, 01:16 PM   #1
CD5Passion
Pin Stripes
ok so my accord is a 96, which means it's been baking the Florida sun for some time, I want to remove the pin stripes because it just ruins the clean look that i want for the body
problem is they are baked on, my friends just came right off, but the adhesive on mine are so difficult, do any of you know any products that wont ruin the paint, and might make the damn things come off a bit easier?
Old 07-02-2003, 01:31 PM   #2
BlackWolf
La Loba Loca
BlackWolf's Avatar
Can you tell if they are paint or vinyl?
Old 07-02-2003, 06:00 PM   #3
pimpinprelude
pimpinprelude's Avatar
if its paint then you are gonna have to repaint that area... but if it vinyl then peel it off and use eather, HOT sopy water.. or rubbing alcohol..(no it wont hirt the paint)! then just wax it good... good luck..
Old 07-02-2003, 07:57 PM   #4
vtracer20
i used some stuff called Goobe Gone or something like that...it takes off the glue stuff after u peel if off....works great...if it's vynal then u should be able to peel if right off while it's hot
Old 07-02-2003, 11:13 PM   #5
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
GOO GONE OWNS!! make sure yo was right after...and let the goo gone "eat up" the paint then try rubbing it off...
RICE....is good
