Old 06-28-2003, 09:47 AM   #1
02_Si
02_Si's Avatar
needs help with clutch definitions
can someone please tell me what the difference is between all of these... What's the diff between organic clutch, ceramic clutch, 4 puck, 3 puck, single plate, etc...
Clutch Kit
Sport
w/ organic disk facing
Flywheel must also be re
placed with HF02 !!
Single Plate Clutch Set. Trans Type: Manual
Clutch Kit
Sport
w/ ceramic-metallic disk
facing; Flywheel must al
so be replaced w/ HF02!!
Single Plate Clutch Set. 3-puck clutch disk. Normal thickness facing. Trans Type: Manual
Clutch Kit
215mm disc; 24 splines
HCC538; HCD822; BRG0110 All
Clutch Kit
Sport
Single Plate Clutch Set. 3-puck clutch disk. Reduced thickness facing. Trans Type: Manual
The name is Tom, I am da bomb, if you can't remember, just ask yo' mom.
02_Si is offline   Reply With Quote
