Old 12-04-2001, 12:49 AM   #1
Turboing accord
What does it take to turbo a Slow A$$ Accord ? I know i'l have to change seals and some internals. What kind oif boost shall i run in order to prevent engine damage ? What gains will i expect from it ?
Old 12-04-2001, 01:30 AM   #2
I don't know a lot about turboing the F22, but I've heard it will take about 7-8 psi stock
Old 12-04-2001, 08:18 AM   #3
so what gains from 7-8 psi stock. what gains ? I think the gaskets and seals are the biggest problem, and replacing them with copper gaskets will allow me for some more. i'm new to this so i really need some help.
Old 12-04-2001, 09:19 AM   #4
Yeah I would check all your seals to make sure everythings good. If you replace the head gasket, Id get a little thicker one to drop compression so you can run a little more boost. You will also want to Make sure you have plenty of fuel and spark so you arent detenating. And Dyno Tuning is always a plus. It will give you an even more reliable motor, and bring out some extra lost power at the same time.:: Sorry I cant tell you how much power youll gain Im not very familar with accords.
Turbo Accords --> Maybe this link might have some info for you.
Old 12-04-2001, 11:04 PM   #5
from how stuff works i got that a turbo that runs 7-9 psi will ad like 50% to the power the engine currently makes, but that is under ideal conditions, but for real it will be somewhere in the 40% range. So running 8 psi will make my engine a 160 hp monster ::
Old 12-05-2001, 08:39 AM   #6
But dont forget this will also leave you with room to grow if you ever decide to build the internals. Thats when you can start turning up the boost. And making some serious power.
Old 12-05-2001, 09:58 AM   #7
if you're gonna stick with mild boost.. then I guess its ok to stick with the f22..
Otherwise I highly recommend a swap. h22/h23
Old 12-05-2001, 01:00 PM   #8
For turbo, I'd get the lower compression H23. With 160 ponies to start with (at the flywheel), you have a good starting point.
Old 12-05-2001, 04:32 PM   #9
93chromeacc
Drop u a Prelude engine in that box style accord and roll wit it.
Old 12-05-2001, 09:54 PM   #10
thats true..
but if you are willing to fully rebuild internals then its not much of a concern..
Besides if you are able to run without disengaging vtec, it'll run like a dream.
Old 12-06-2001, 01:37 AM   #11
MrCLoWnY
Sup Hondaman! How many miles do you have on your motor???
I think an engine swap is the best choice but if i was you i would just get a turbo. It has so many cool things that comes with having a turbo. For instance nothing beats that blow off Whooshin. And the sound of your turbo spooling is dope too. So get the turbo and you'll not regret it. I mean my turbo made my slow ass SOHC CIVIC a contender on the streets. No check that i mean a car to fear!. = ) But whatever you do good luck.
Old 12-06-2001, 09:41 PM   #12
the engine has like 121k clicks on it. at leat the last 30 3k miles were driven hard, maybe too hard. This summer it was in great shape when i took it apart.
Old 12-16-2001, 10:14 PM   #13
toykilla
heres how to tell power...say 1psi = 10hp 7-8psi is you guessed it folks 70-80hp. if you couldnt figure that one out then you need to study HARDER...=)
Old 12-17-2001, 01:49 AM   #14
MrCLoWnY
Don't worry about the mileage. Its all good. Just go get a compression check and see how your engine is. I Mean i have a blown headgasket and i still drvie hard. SO if i were you just turbo your ride.
Old 12-20-2001, 12:48 AM   #15
importboi22
stock 96 lx accord 80k stock clutch stock exhuast 62 or 64mm TB
164hp and 167 ft tq
stock
108 hp and 135 ft tq
Old 12-20-2001, 02:37 AM   #16
MrCLoWnY
Hey Import boi how many lbs were you boostin??
WHere did you get your car dynoed at and how much???
i live in torrance.........
Old 12-20-2001, 11:48 AM   #17
I'm curious also. And thanks for posting the dyno btw
Old 12-20-2001, 10:41 PM   #18
importboi22
4psi seriously it was 4.2psi gotta love sohc cam less valvetrain = higher tq output wooot woooooot go sohc non vtec mutha ****as take that ish vtec lovers
Old 12-20-2001, 10:43 PM   #19
importboi22
oh ya did i mention that we had a checkengine light on too
Old 12-21-2001, 10:07 AM   #20
humm, that looks pretty good for 4psi..
Old 12-22-2001, 10:18 PM   #21
gixer
another thing you have to take into consideration is compression vs. boost. boost basically raises the compression of the engine. a 10.5:1 compression engine will make more hp with 8lbs of boost compared to an 8.5:1 engine boosting 10lbs.
for ex. i have two friends, one with an itr turbo, 7lbs boost, and another with a gsr turbo, 10lbs of boost. both dynoed their cars and got almost identical charts.....240whp-type-r.....243whp-gsr.
Old 12-22-2001, 10:57 PM   #22
ajn
but in stock trim the itr has about 20 more horsepower than the gsr. It makes sense.
Old 12-23-2001, 04:14 AM   #23
gixer
but when your talking about boost, stock figures almost gets ruled out.....displacement plays the key role....and since itr's and gsr's have the same displacement....the output will be almost identical.......
Old 12-23-2001, 07:14 PM   #24
importboi22
another thing boost just raises your compression Ie if you took exactally half of atmospheric pressure ( 14.7psi) it would be 7.35psi and if your stock compression is 10:1 it would be 15:1 after 7.35psi boost i hope you guys are getting what im saying
Old 12-24-2001, 02:48 AM   #25
gixer
i vividly stated that above......great details......
Old 12-24-2001, 02:51 AM   #26
importboi22
gixer can i get your supra tt the only thing i got is a 89 t2 rx7 :( it doesnt run but it will be soon prolly gonna do a t72 turbo conversion work that mutha up some hurley racing seals * drool *
