Go Back   HSTuners > Classified Ads > Parts For Sale/Trade
Old 06-03-2003, 10:50 PM   #1
LECKEY73
Parked
LECKEY73's Avatar
4 Sale Venom 400 Performance $200.00
$200.00 + SHIPPING Call if U R intested 1917-871-1098
The VENOM 400™ Performance Control Module is an add-on control unit that features its own micro-controller. This module is connected to the vehicle's sensors and increase engine performance by monitoring the sensors output characteristics and modifying the input to the existing vehicles computer.
VENOM 400™ Advantages
The VENOM 400™ improves horsepower by as much as 25% through the range of approximately 1,000 to 5,000 RPM. The VENOM 400™ is OBD II compatible. Besides a substantial increase of torque, the VENOM 400™ reduces flat spots or delay time during sudden acceleration.
The VENOM 400™ incorporates an 8-bit micro-controller that is capable of monitoring the various sensor inputs and modifying their output at more than 40 times per second.
If you have already installed a performance prom, the VENOM 400™ will enhance the vehicle's performance beyond the parameters set by the performance prom.
The VENOM 400™ is only active when peak performance is required. During normal driving, the VENOM 400™ remains passive until the microcomputer determines that engine airflow and throttle position warrants increased performance. Normal fuel economy prevails while under normal load.
The VENOM 400™ enhances the performance gains achieved by installing an upgraded chip. Whatever the gains are as specified within the chip, they will be magnified through the use of the VENOM 400™.
The VENOM 400™ has an off switch so smog certification is achieved when not racing.
The VENOM 400™ will not trigger the emission safeguards of today's vehicles.
Easy installation in 20-30 minutes with basic hand tools requiring only four electrical connections.
Red cockpit LED indicating VENOM 400™ activation.
Up to 25% more increase in horsepower throughout the power range of 1,000 to 5,000 RPM (where the vehicles red line is 6,000 RPM).
The flat spot or delay found with automatic transmission downshifts, which can be as much as three seconds, is eliminated (when equipped with auto instead of manual$200.00 + SHIPPING
LECKEY73 is offline   Reply With Quote
