Old 06-02-2003, 08:57 PM   #1
OPAKRACING
Boring and stroking....
I've had a few questions about this....stroking is basically making the stroke longer there for increasing liters, am i right? and boring is actually making the cylander wider, am i right?
So when you want to make a car a 2.0 liter for say, better torque...do you use a healthy mix of both stroking and boring, or do ya just bore the hell out of it til its a 2 liter?
Thanks for the info guys
Old 06-02-2003, 09:46 PM   #2
dont do it...take it to a shop...and im pretty sure a 1.8L cannot be made into a full 2.0l (like i said in the post where you thought of this idea 1.9x is the limit...unless you want paper thin cyls)
Old 06-02-2003, 10:28 PM   #3
OPAKRACING
ah ok, well with that said, what about stroking and stuff liekt hat, would you rather stroke instead of bore, or do you do both, i don't know.
Old 06-02-2003, 11:43 PM   #4
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
I dont think its good to put a stroker on a civic engine. I think its due to the size limitations. Not to mention sleeving the block is like 10x easier and cheaper.
everyone loves the turbizzim.
Old 06-03-2003, 03:40 PM   #5
boring alone will get it close enough to a 2 ltr, anyone know how many liters are in a b18c???
1.797 close but not actually 1.8ltrs
my d16z6 is really a 1.590 ltr engine.
a b16 is really a 1.587 ltr engine.
Old 06-03-2003, 04:25 PM   #6
didnt I say that?
edit**nope not here...musta been somewhere else...I know I did...I think Im losing it
Old 06-03-2003, 11:17 PM   #7
OPAKRACING
So jsut by buying new sleeves, ic an buy them already bored to a 1.9 er whatever the number is? or do i resleeve then bring it to a machine shop for the bore?
Old 06-04-2003, 12:37 AM   #8
TeriyakiBroccoli
5th Gear
no, you can send the to the machine shop to bore first, then to put in sleeves.
Old 06-04-2003, 07:10 PM   #9
OPAKRACING
Ahh, i see...thank you...and btw, this would all be done to a b18c1...not my wimpy stock motor. hehe
Old 06-10-2003, 11:59 AM   #10
huh? how is that since theyre boring the new sleeves?????????
Old 06-11-2003, 08:24 PM   #11
OPAKRACING
Send the sleeves to the shop, and then install them after the bore....
Old 06-12-2003, 03:01 AM   #12
uhh yeah thanks for just repeating someone elses wrong info, good job!
Old 06-12-2003, 10:05 PM   #13
TeriyakiBroccoli
5th Gear
I was under the impression that they bored out the cylinder, put in the new sleeves, and rebored the sleeves to size.
Old 06-13-2003, 02:41 AM   #14
OPAKRACING
Uhh, i didnt know it was bad info...hence the whole reason for this thread, thanks!
so im confused, whats the deal with this? heh:o
Old 06-13-2003, 12:24 PM   #15
TeriyakiBroccoli
5th Gear
regardless of procedure, just send your stripped block to the machine shop, rebore/resleeve.
