Old 05-14-2003, 07:29 PM   #1
clanracer
Which is the best deal
hey guys. curious to know which you think is the best of these two deals for my 98 civic ex coupe.
Honda Acura Integra B18C 98-00 Integra Type- R and is 5300 shipped - DOHC VTEC 4 Cylinder 16 Valve • Hydraulic LSD Transmission • Redline: 8900 rpm • Diplacement: 1797cc • Torque: 134 lb-ft@7500 • Horse Power: 210hp@8000 • Compression Ratio: 11.0:1 This engine comes as a COMPLETE swap with tranny, ECU, motor etc... Ship time is 5-10 business days and can be tracked on this site. Engine is JDM with approx. 35-45K miles on it.
Or...
Honda Acura Integra B18C 94+ GS-R and is 3350 shipped - DOHC VTEC 4 Cylinder 16 Valve • Hydraulic Transmission • Redline: 8200 rpm • Diplacement: 1797cc • Torque: 129 lb-ft@6200 • Horse Power: 180hp@7600 • Compression Ratio: 10.6:1 This engine comes as a COMPLETE swap with tranny, ECU, motor etc... Ship time is 5-10 business days and can be tracked on this site. Engine is JDM with approx. 35-45K miles on it.
im probably going to eventually go turbo. i will also need your ideas on how to build it up so i can spank all my friends. thanks for all the help.
Old 05-14-2003, 07:31 PM   #2
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
thats a hit out of the ball park, b18c1 fo' sho.
can be built to go NA or Turbo without breaking your bank, and still provides a kick while you choose which route to go.
everyone loves the turbizzim.
Old 05-15-2003, 01:12 PM   #3
clanracer
If i was to go the B18C1. what other parts would i need for the swap to be complete.
Old 05-15-2003, 01:13 PM   #4
clanracer
also how long do engine installs usually take.
Old 05-16-2003, 04:40 PM   #5
engine installs are based on knowledge so i couldnt really tell you how much time itd take you to install a motor.
it says......COMPLETE SWAP.
but you'll need an extension welded onto the exhaust i believe.....or some of it cut off, i forget.
go C1.....c5 + turbo takes a lot of tuning to run nice....a LOT of tuning.
to be honest though......if its not going to take long for you to go turbo, id snatch up a B16A w/ LSD instead.
Old 06-10-2003, 01:20 AM   #6
Jazn671
Jazn671's Avatar
if you have a friend or 2, all the tools, the swap should be done in about 8 hours. go with the gsr b18c1 motor. a red valve cover and and extra 20 horses isn't worth an extra $3k.
Suja 1 Motoring
502 E St. Charles
Carol Stream, IL 60188
630-407-0711
www.suja1.com
AIM:Jazn671
Old 06-10-2003, 01:40 AM   #7
i'd say the b18c1.
