#1 |
Throttle body size...
For a turbo b18c1, whwat size throttle body should i get?
#2 |
70mm would be best...
Suja 1 Motoring 502 E St. Charles Carol Stream, IL 60188 630-407-0711 www.suja1.com AIM:Jazn671 |
#3 | |
well, if its too big, then i'll lose back pressure and that means i lose low end torque....so are you sure a 70mm would be best for a turbo b18c1? |
#4 | |
You'll lose velocity not backpressure, but with a small fast spooling turbo it wouldnt matter too much anyway. I wouldnt even bother switching it out. |
#5 |
too big? i'd say it's too big for factory compression for a naturally aspirated honda but for a turbocharged honda, you'd want a 70mm throttle body streetable... you'd see up to 85 mm on 25+psi drag hondas...
#6 | |
i see...thanks. |
#7 |
I make quite a bit on a 65mm and it revs to 10.5K. If you want more Edelbrock will release a 70 and 75mm with an adapter in June
| Thread Tools | |
| Display Modes | |
