Old 04-22-2003, 01:47 PM   #1
robdog
Snow
I would like to lower my car this summer but i live in a part of PA that gets 100" + of snow a year. Any comments on how a lowered car does in the snow...would it be too much of a hassle??
Old 04-22-2003, 02:08 PM   #2
There is a good solution to this: coilovers. You can raise or lower your car whenever you want.
Old 04-22-2003, 02:44 PM   #3
well i went with a lowered car all winter long. no problems here, thou sometimes i could use the car as a snow plow
Old 04-23-2003, 02:28 PM   #4
robdog
something i was always confused about, what part exactely do coilver's play in suspension? Is it the spring system or the whole shock and spring? I have the Koni Yellows on factory springs, can i get coil over system with these?
Old 04-23-2003, 02:39 PM   #5
Since you already have the struts, you'll want coilover sleeves, such as Ground Controls (probably the best sleeves). These are basically springs with adjustable perches to allow you to change the height of your car.
Old 04-23-2003, 03:14 PM   #6
robdog
how hard is it to adjust?
Old 04-23-2003, 03:16 PM   #7
robdog
would this be what i need?
http://inlinefour.com/grounconcoil.html
Old 04-23-2003, 03:20 PM   #8
Yes, that's what you need. I think there might be an adapter to fit Konis though, so check that out.
Adjusting shouldn't be too hard (I can't say for sure because I don' thave them). Keep them oiled so they don't rust. You loosen the hold down and turn the adjustment ring to get the desired heigh, and tighten them down again AFAIK. You'll probably need to take your wheel off.
Old 04-23-2003, 03:21 PM   #9
robdog
well thats not a problem considering im only going to do it twice a year..thanks for your help
