Old 04-15-2003, 05:43 PM   #1
rody084
weird wear on my left side tires...
hi,
I have a 1990 Integra GS, i've had it for about a month now, and today i took the left wheel off and noticed that about on the inside part (about 1-1/2 inches) is completely bald, but the rest of the tire is fine... i looked at the back tire on the same side (left side) and it has the exact same thing. My tires on the right side are just fine, all even. but these on the left, they have this area on the inside which is completely balded. My mechanic has told me earlier that i need a rack and pinion job, my alignment is a tiny bit off, and my rotors are slightly warped (these are the problems that I know of).
anyone have any ideas as to what might be causing this?
Old 04-15-2003, 07:08 PM   #2
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
hmm, take it to the alignment shop and try get it diagnosed there.
everyone loves the turbizzim.
Old 04-15-2003, 08:02 PM   #3
so the insides are worn. is the car leaning to the right ???
Old 04-15-2003, 08:41 PM   #4
rody084
the car does pull to the right whenever i hit the brakes
Old 04-15-2003, 09:28 PM   #5
Definately take it up to the alignment shop and have it checked out.
Old 04-20-2003, 01:59 PM   #6
Dezoris
Worn suspension components bushings, etc. May be a problem here.
When you are on the rack for an alignment, they should check for abnormal play in the suspension components.
Better yet take this car to the body shop and see if it was hit on that side.
Your frame may have been tweaked, and for these type of repairs most body shops will send the car off for an alignment to get it as close as they can, adding camber correction kits are usually never done, to save money and time.
Old 05-19-2003, 06:09 PM   #7
pimpinprelude
pimpinprelude's Avatar
hummmmm the car could be heavy on one side?? do you have a fat g/f??
Old 05-19-2003, 06:58 PM   #8
not the gf comment. i noticed that on hondas the crossbones thend to slip to the left causing more negative camber on the left wheels and the front right caster angle tends to get smaller causing the car to pull, and be unstable at higher speeds. any of that happened to you ?
