Old 04-11-2003, 05:33 PM   #1
krz2fer
krz2fer's Avatar
Exclamation HOT exhaust?
I installed the axle back portion today and the only reason I noticed how hot it got after a drive is because I get anal and paranoid after installs. Anyway, after a drive I get out and inspect the rubber gaskets and bolts to make sure it's all holding fine. I notice basically some steam coming off where the two pipes connect... and I wondered if it normally did that. I touched it and basically almost burned my freakin fingers off. Is that intense heat normal for exhausts? I've never dealt with them so I didn't know either way. Thanks for the help.
krz2fer
