Old 04-02-2003, 07:44 AM   #1
krz2fer
krz2fer's Avatar
catback install
Getting an OBX full cat for my 92 civic... can anyone point me in the direction of install instructions for this model, or general ones that'll work? I don't want to pay for this install since it's just bolt on and Im sure me and a bud can do it. Thanks for the help in advance!
krz2fer
Old 04-02-2003, 10:41 AM   #2
Don't sweat it. Jack your car up, and I'm sure you can figure it out. Take out a couple bolts, take off a couple hangers, and put everything back with the new exhaust. It's about the simplest install next to a shift knob.
Old 04-03-2003, 12:50 PM   #3
krz2fer
krz2fer's Avatar
Does it matter what section I remove or put on first?
And will WD-40 work to loosen gaskets and bolts or do I really need penetrating oil?
krz2fer
Old 04-03-2003, 08:22 PM   #4
Jazn671
Jazn671's Avatar
tips
it doesn't really matter which section you take off first... generally, the a-pipe directly on your cat is the first to come off then everything else just comes off... wd-40 will help a little, if it don't work, it's probably gonna have to get cut off... the wd-40 will help alot on your hangers...
Suja 1 Motoring
502 E St. Charles
Carol Stream, IL 60188
630-407-0711
www.suja1.com
AIM:Jazn671
Old 04-03-2003, 08:26 PM   #5
ShEaNy
ShEaNy's Avatar
shouldnt be to hard at all..just a few bolts and hangers..and it should fit right in....basically what everyone else said..
