Old 03-29-2003, 09:40 AM   #1
cashizslick
Power Window Not Working
The power window on the passenger side of my car is not working. I doubt it is the motor, because the motor was replaced a few months ago and was showing no signs of wear. What else could go wrong to stop my window from working?
Old 03-29-2003, 11:54 AM   #2
hmmm maybe it came unplugged if you worked on it, and didn't put it tight there.
Old 03-29-2003, 12:48 PM   #3
cashizslick
It seems that way - cause the window just does not work now - could it be some kind of retainer inside the mechanism that broke?
Old 03-29-2003, 01:13 PM   #4
beats me but if the motor is burn now it looks like you have to go deeper into wireing to find a short or something
Old 04-04-2003, 01:25 AM   #5
turbowhat_n_dat
did you check the manual override switch??
The little flip switch on the arm rest is it in the on or off position.
Maybe the 94's dont have them if they dont disregard.
G FLICK
Old 04-07-2003, 06:47 PM   #6
SilverCiv
LOL, this is a problem on all Honda Civics, manufacturer error The reason for this is the windows are on the tracks reaallly good, the MOTOR is fine Try WD40
Old 04-19-2003, 02:29 AM   #7
HndaTch627
sounds to me like your run channel has dried out causing the window regulator(the thing it moves up and down on) to bend. It's fairly common. Not to say it couldn't be the motor or the switch but on a civic that would be very very uncommon.
