Old 11-26-2001, 10:24 AM   #1
230 HP on stock D16?!?!?!
Fmax claims that their Civic kit for the EX can produce 230 HP and 212 Ft-lbs of torque at 12psi, with these mods:
Stock Engine: Lower compression ratio via head gasket option, Stock Camshafts, Stock intake and exhaust porting. Stock pistons rods, rings and crank.
Bolt-on turbo system: Components listed on the Honda/Acura turbo systems page
Ignition timing: Stock initial timing with .2 degrees of retard per pound of boost
Boost level: 13-15 psi of boost
Fuel additive: None, 92 Octane
Other Mods:
AEM cam gears, 3" exhaust, after-market ceramic clutch and APEX'i AVC-R boost controller
96 Civic EX Dyno Chart
If this is true its pretty immpressive. Maybe there will be some hope for our little D16's...
