Old 03-27-2003, 01:24 AM   #1
accordracer84
Best Security System
I wa talking to this guy tonight that helped build a car that won USAC world finals a couple of years back and the security system on this in unbelievable. The guy bought the smallest camera for a car you could buy and put it in the c-pillar opposite the driver side and pointed it towards him. he wired up a tape rocorder that would turn on any time that the alarm would go off and it would record the intruder. The recorder was in a solid steel box that you would not be able to open unless you had a plasma cutter and you would never be able to find the box any way. They also put 2 more battery's in undisclosed locations in steel boxes for the alarm and tape recorder. Even if the car was started the alarm would still keep going off. When you have over $40,000 worth of equipment in your car then you gotta protect it somehow. The car is well worth over $100,000 and by far the best and most spectacular install i've ever seen. Well that's just an idea for you all! Have fun
Old 04-10-2003, 07:02 PM   #2
autocrossthugg
autocrossthugg's Avatar
sounds great, wish i had the money to put into a system like that. oh, well have to settle. I wish alarms would only go off if someone near cars "thought" about stealing sh*t, THAT would be worth something!!! lol
Ground Control Coil-overs
Eibach springs
SPC Camber Kits (f&r)
Front Upper Strut Bar
Rear Lower Bar
3-point Sparco Harness
