Old 03-26-2003, 09:55 PM   #1
Prophcy0
Whining/screeching type noise
I have a 94 Civic EX, and a lot of times when I back up and cut the wheel (turn) this screeching/whining type noise comes from somewhere on my car. I think it's from somewhere in the back, but I am not certain. This sound has also happened once or twice when I made a sharp turn from one road to another. Anyone have any idea where this sound is coming from and how to fix it?
Old 03-27-2003, 12:42 AM   #2
autocrossthugg
autocrossthugg's Avatar
i'd first look at your steering system and then maybe your braking system.
Ground Control Coil-overs
Eibach springs
SPC Camber Kits (f&r)
Front Upper Strut Bar
Rear Lower Bar
3-point Sparco Harness
Old 03-27-2003, 10:57 AM   #3
yeah to me it almost sounds like worn pads or warpted rotors rubbing unevenly...
A good idea is get someone so stand outside with you and you back around for awhile...they could tell you where the sound is really coming from...
We need more info...
Old 03-27-2003, 12:43 PM   #4
JDMB16
check your brakepads
Old 03-27-2003, 05:06 PM   #5
Prophcy0
Thanks for the replies. I'll try to find out exactly where the sound is coming from sometime this weekend.
Old 03-27-2003, 06:49 PM   #6
Honda530
Check your cv Joints too. Maybe it could be a rubbber joint that needs lubrication.
