Old 08-17-2001, 07:21 AM   #1
Fugitive
RedLine
How harmful is it to the engine to shift at the redline? I shift between 7500-8000 rpms (my VTEC engagement point is at 5800 rpms)
Old 08-27-2001, 11:29 PM   #2
JayZ
Shifting Points!
I would say that what alot of people refer to as tachin out is not a very good thing. Lots of engine problems can occur especially in honda which are known to have weak crower rods. But about the shifting point, you want to try and shift at the top of your power band or just when you reach maximum power. Most honda maximum power occurs 300 to 500 rpm's before the redline. You just need to feel and listen for it basically. Hope this helps, if not feel free to email me.
Old 08-29-2001, 07:15 PM   #3
well, actualy you want to shift past peck so you can be higher in the power band to get back to peak power again. i found that 7200-7500 rpms is a good shift point to stay in vtec, if you fall out of vtec then you wont be nearly as fast.
Old 08-30-2001, 10:11 PM   #4
HondaBrain
Well I would definitely agree with 4thgenlude (guy has alot of knowledge). You do not want to fallout of vtec or you will certainly lose time. About running into the redline, try not too. I have done it a couple of times slightly with no problems, but you never know how much your engine will take. Good Luck
Old 08-31-2001, 11:49 PM   #5
Re: RedLine
why is your vtec engagment so high? id try to get it back to stock
Old 09-02-2001, 09:35 PM   #6
VN-Tec
I mis shifted my car up to 9000 before :(
Old 09-10-2001, 11:34 AM   #7
Mugenlude
Pro: Shifting at redline gets you more power in the next gear because your revs are higher, even if your power is actually decreasing a little from 7000-7400 RPM's (7500-8000 on most of our tachs). This leads to quicker times.
Con: Running you car to redline constantly will oviously decrease your engine life.
This may sound bad, but you should run your car to the fuel cutoff once just to see where it is. Most 5th Gens (don't know about 4th Gen) have a fuel cutoff on the stock tach at ~8000. However, mine is at ~7800. It won't hurt it to do it once or twice, that is what the cutoff is for. Once you find the cutoff, in order to get the quickest times, you should shift just before the fuel cutoff.
hope the helps...
Old 09-10-2001, 11:34 AM   #8
Mugenlude
Old 09-10-2001, 07:16 PM   #9
Big James
Re: Shifting Points!
Weak crower rods in a stock Honda? Huh?
Like everyone has stated, even though our cars are made for high RPM's, does not mean that it does not put some extra wear on it. On a side note, my car has an 8,500rpm cutoff.
Old 09-11-2001, 02:23 PM   #10
8200 on stock tach, oops :(
Old 09-12-2001, 02:51 AM   #11
2000_Honda_Si
I redline the hell out of mine, sometimes that redline just sneaks up on you, just when you begin to pull your like wtf? Redline already? Shiiiiiiiiiiiiiiiiift!!!!! heheheheh
Old 09-12-2001, 06:31 PM   #12
VN-Tec
but 9000 shouldnt be a prob with my car.. I heard those guys at Tech3 say i could take it up to 10,000 Never have i tried tho...
Its kind of crazy becayse the tach went off the gauge last time..
Old 09-12-2001, 07:12 PM   #13
thats when you invest in a autometer tach.
