Old 03-23-2003, 12:59 AM   #1
drdingo21
drdingo21's Avatar
The dam Squeaking
My brakes squeak everytime i use them, and sometimes when im just driving around the will squeak for a second and then stop.
I have 4 wheel disc breaks and im not sure where its coming from so i replaced all 4 rotors and pads. That stoped it for about 10 minutes, then it goes right back to doing it again. So then i put the anti squeak compound on the back of the pads, that also stoped it for about 10 minutes and then same thing. Last night i went to Advancded auto parts and the guy said to try this spray, tried that it lasted about 5 minutes and then same thing.
Please some one give me some worthwile advice so i can stop it. Its so annoying and embarsing.
Old 03-23-2003, 01:08 AM   #2
ohiochica
ohiochica's Avatar
dr dingo ..if you get oem brake pads they wont squeak.
to all our military: my thoughts and prayers are with you, come home safe and come home soon.
Ohio HST members please read this
ohiochica is offline   Reply With Quote
Old 03-23-2003, 12:13 PM   #3
and if u install them correctly they won't squeak. make sure they are not wearing uneven cause no spray and no silencer compound will stop that.
Old 03-23-2003, 03:31 PM   #4
drdingo21
drdingo21's Avatar
They are installed correctly and are not wearing un even. Would i pick up OEM pads from a dealer? Any idea about how much they cost?
Old 03-23-2003, 07:03 PM   #5
I'd suggest ordering them from manchester honda online... they'll be cheaper than if you walk into a dealer.
50-80 bucks each plus pads. about 20-40 bucks for both sides...
http://www.manhonda.com/ap/index.cfm?Level=21&PG=0
Old 03-23-2003, 07:46 PM   #6
drdingo21
drdingo21's Avatar
i will give them a try, im just gonna order the front pads. i hit up adnacded auto parts and the guy said to really try to lock up the brakes. So i got up to 80 on the way home tonight and just laid into them. Im hoping that will do it, but if not then i will go through the link you gave. Thanks
Old 03-24-2003, 05:22 AM   #7
Re: The dam Squeaking
Originally posted by drdingo21
My brakes squeak everytime i use them, and sometimes when im just driving around the will squeak for a second and then stop...
Your rotors are shot! Get them Blanchard ground , or replace them; your choice.
Here, do yourself a favor --- read and study this:
http://www.stoptech.com/whitepapers/...otors_myth.htm
Read between the lines --- it will solve ALL your problems...
Old 03-24-2003, 10:47 AM   #8
drumboy69
Just to add my two cents. I was told by a Honda mechanic that the best way to get rid of the brake squeaks is to have OEM pads installed. Hondas are touchy that way and non OEM pads on OEM rotors may not brake quietly no matter what you do...
Drumboy69
Old 03-25-2003, 10:19 PM   #9
drdingo21
drdingo21's Avatar
Re: Re: The dam Squeaking
um, as i said in my first post the rotors are brand new and by brand new i mean less the 2k miles.
I think its the pads, they are autzone crap, so ill try the link that was posted before.
Old 03-25-2003, 10:38 PM   #10
keystone
are they stock replacement rotors or sloted or something, could be wrong type of pad material
