Old 03-14-2003, 05:00 PM   #1
themadhatter
accord engine?
can i put a accord engine in to my 91 hb civic the 4c or 6c would do but i cant find any info on this swap can 1 of u fine folk help
Old 03-14-2003, 07:10 PM   #2
autocrossthugg
autocrossthugg's Avatar
what trim level is your hb & what motor do you want to put into your hb???
Ground Control Coil-overs
Eibach springs
SPC Camber Kits (f&r)
Front Upper Strut Bar
Rear Lower Bar
3-point Sparco Harness
Old 03-14-2003, 08:24 PM   #3
keystone
seriously if you are going to swap in the f or the h series I would go for an H22 if i had the money to do it, why bother with the f series from the accord, but a v6 hatch would be sweet if it would fit, but I don't know.
Old 03-15-2003, 02:36 AM   #4
why in the world would you settle for a f2x engine ? the aftermarket support for them is weaker than the h22 and the j engines will be too heavy and underpowered, plus they come only with an automagic transmission ????
