Old 03-12-2003, 10:17 PM   #1
maxfli7677
Individual Throttle Bodies
I'm gonna make this short and sweet. Is it possible to turbo an ITB setup???? And if so, what would be involvd in doing so???
Old 03-13-2003, 01:13 AM   #2
Well, I guess you could, but it would be pointless.
You'd need four very small throttle bodies, a custom made intake manifold, and you'd probably have to remove your firewall.
Old 03-13-2003, 05:31 PM   #3
maxfli7677
the largest throttle body i can find is 70mm for an h22, versus the ITB setup that has four 50mm ports. Thats 200mm total vs. 70mm; why is that pointless????????
Old 03-13-2003, 05:49 PM   #4
50mm ports ? that's the radius or the diameter right ?
Old 03-13-2003, 06:07 PM   #5
maxfli7677
50mm is the diameter.
Old 03-13-2003, 06:08 PM   #6
maxfli7677
yes the diameter
Old 03-14-2003, 01:09 AM   #7
Because with FI it's all under pressure, anyway. A lot of engine building physics/basics go out the door with FI.
Do you realize the size of the blower you'd have to run with four 50mm ITBs? The injectors to keep up? The number of motors you'd go through? It's pointless.
