#1 |
It has 4 Doors...
Which wire for Tach?????
Hi all.
I've got mu Autometer guage all mounted into my car and all and I have everything operational but my hook up to the coil to actual get my read out. does anyone have a pic of the wire they tapped into at the cluster/ECU or Distributor that I can use to go by? this would be great. I have tried to decode the Haynes manual to do it but that's a waste of my time. Appreciate the info. Thanks.... |
#2 |
i dont have a pic but the wire is really easy to locate... if you know where your distributor is, you'll see to set of connectors w/ wires.. you want the connector w/ 2 wires.. those wires are going to the positive and neg. of the coil.. the BLUE wire is the negative signal... tap into that (do not cut wire) and youre all set... i just did this project for my 94 dx... goodluck!!!
#3 |
It has 4 Doors...
Thanks for the info SWIFT...I could have swore that I tapped into that once last time and it spun the Tach needle the opposite way...
I'll look at see..thanks ![]() |
#4 |
It has 4 Doors...
it was indeed the Blue wire on the one plug...thanks for the info
works like a charm now... ![]() |
#5 |
anytime... :
: post some pics so we can see it... i will too when im done w/ the film.. |
| Thread Tools | |
| Display Modes | |
