Old 03-02-2003, 05:47 PM   #1
General Chang
alignment question
Everytime I turn sharp my rim hits my tie rod and creates a crunching sound. My rims are half an inch deeper than my last ones so that is what is causing me all this trouble. anyway, my question is, if I swapped tie rods from either side so that the bow in the rod faces towards my strut instead of outward will this be alignable? a buddy of mine says reversing the tie rod will affect the toe-in. I turned the wheel all way to see if the bow in the tie rod was their so it wouldn't hit the strut and this appeared to not be the case. i can't stand having to do 3 point turns just to get into a tight parking space
Old 03-02-2003, 06:01 PM   #2
i don't think you could put them the other way. you might end up with them hitting the control arm
Old 03-02-2003, 06:06 PM   #3
General Chang
i turned my wheels all the way to see if that would happen and it appeared their would be enuff clearance if I reversed em.
Old 03-02-2003, 06:18 PM   #4
there is one more problem: the treads i don't think they will go in
Old 03-02-2003, 06:25 PM   #5
General Chang
damn, thats tru.....have u heard of some custome tie rods??
Old 03-02-2003, 06:37 PM   #6
How wide are your wheels? Offset?
Old 03-02-2003, 07:09 PM   #7
no custom tierods. maybe some wheel spacers will help you out a bit
Old 03-02-2003, 07:20 PM   #8
General Chang
my old wheels were 5 and a half and the new ones are 6
Old 03-02-2003, 07:21 PM   #9
General Chang
i was thinking about wheel spacers.....does anybody sell them?
Old 03-02-2003, 07:26 PM   #10
the local autoparts stores
Old 03-02-2003, 07:28 PM   #11
General Chang
damn....one place wants 120 dollars for a spacer....bet I could get a machine shop to make one for 20. btw, how many millimeters are in an inch?
Old 03-02-2003, 07:33 PM   #12
1"=2.54cm=25.4mm
Old 03-02-2003, 07:37 PM   #13
General Chang
what is offset?
Old 03-02-2003, 07:40 PM   #14
http://www.hondastyle.com/forums/sho...&threadid=8180
Old 03-02-2003, 07:45 PM   #15
General Chang
thanx.....its positive offset.....can a machine shop offset it any more?
