Old 08-17-2001, 07:13 AM   #1
Fugitive
Rear Sway Bar
Is anyone familiar with how difficult this installation is? I looked at chilton's but isn't telling me a whole lot.
Old 08-29-2001, 07:39 PM   #2
advanracing62
what car??? Who makes the bar????
Old 08-29-2001, 11:52 PM   #3
hondafetish
Not that I have done it myself, but I think if you find your stock sway bar, you can pretty much figure out what will be required in switching it out for a larger-diameter aftermarket peice.
Old 09-04-2001, 10:16 AM   #4
Boosted3g
Im assuming that you probably have a 90s civic or integra. The rear is only held on by a few bolts and it really jsut a straight forway swap. The front on the other hand it a little more involved and you have to drop some of the exhaust. If you have a 2 peice header it is not big deal but if you have a turbo or a one peice header its a pain.
Old 09-04-2001, 07:46 PM   #5
2000Pimpinex
Super Moderator
2000Pimpinex's Avatar
The rear is very simple to do. Just a couple of bolts and its done.
2008 Mustang GT
1998 Hatchback SOLD
1985 Ford Bronco XLT 5.8 351W
w/ 33X12.5X15
Old 09-10-2001, 07:33 PM   #6
Wider Rims will help but a swaybar will help more.. just make sure you dont get to thick of one because you can cause a lot of unwanted oversteer
Old 09-15-2001, 10:00 PM   #7
Dezoris
Most all good bars will reqiure some drilling to the sub frame. not hard though. The easiest var to install is the Suspension Techniques, where you will not have to remove the control arm bolts at the sub-frame.
I'd say regardless of which bar you pick it will be a 2-3 hour project without a lift.
