Old 02-20-2003, 12:33 PM   #1
Jtmoney025
Cams
I have a D16Z6 motor and I do not know which cams I should install. I plan on doing many mods except a turbo. What I am thinking about is a stage 2 COMP cam. Please anyone have any ideas or what cams do you have? Thanks Jason
Old 02-21-2003, 07:15 PM   #2
delsolvtec
Del Sol Forum Moderator
delsolvtec's Avatar
Your best bet is to select a cam manufacturer and give them a call. Tell them what your goals are with the car and they will point you in the right direction as far as cam size and stuff.
1994 Mazda MX6 - For Sale
Old 02-22-2003, 11:27 AM   #3
True that.
Skunk2 makes good shit. I've never heard anything bad from them.
Old 02-22-2003, 09:11 PM   #4
96coupe
i like the skunk2's too. i'd go w/ skunk2 stage II w/ skunk2 valvetrain. its a good idea to get a new valvetrain w/ stage II, III... cams.
Old 02-23-2003, 03:33 AM   #5
Im asking this question because I do'nt know the answer.
WHy?
Old 02-23-2003, 04:12 AM   #6
pissedoffsol
skunk2's aren't out yet.
Zex, which is made by compcams, is the best sohc cam out right now.
Old 02-24-2003, 12:22 AM   #7
96coupe
yep, you are right, for some reason i thought they were out.
one reason to upgrade the valvetrain w/ the stage II's is that the manufacturer recommends it, and it is never a bad idea to follow the advice of the people putting the product through many tests. another reason is the stock valvetrain will not be very reliable w/ the more aggressive cams, so it is a good idea to go ahead and replace the valvetrain at the same time to avoid any headaches. it is also easier/quicker to do both installs at once.
Old 02-24-2003, 01:11 PM   #8
What would you be replacing then?
Old 02-26-2003, 12:26 AM   #9
96coupe
valves, valve-springs and retainers
Old 02-27-2003, 03:10 PM   #10
DelSoul
If you have the extra cash put it into toda racing parts, they're really good pieces.
Old 03-03-2003, 05:34 AM   #11
pissedoffsol
toda doesnt make d-series parts. jump off the band wagon retard
