Old 02-19-2003, 11:13 PM   #1
97CivicBoy
Help Do I Need To Change The Wiring??
I ALREADY HAVE THE A 300 WATT WIRING KITT TO MY SELF POWERD BASS TUBE NOW...I JUS BOUGHT A 700 WATT 10" SUB WITH A 1000 WATT SINGEL CHANNLE OR 500 WATT DUAL CHANELL SUB...IT CAME WITH A WIRING KIT OF 1000WATTS...DO I NEED TO RE DO THE WIRING FOR THIS SUB...OR CAN I LEAVE IT..IT WAS SUCH A PAIN TO WIRE IT:o ..HOPE I DONT HAVE TO DO IT AGAIN..LEMME KNO THANX
Old 02-20-2003, 12:03 AM   #2
a96710
a96710's Avatar
You don't have to...but it's a good idea. You're runnin more power so you'll need to get more power to the amps. Your amp will run better though with larger cable. The watt kits are just different size guages.
Old 02-20-2003, 12:27 PM   #3
97CivicBoy
will it mess up my wiritn kit i got now...and also umm it wont blow ne thign out like a fuse on the wiring kit rite
www.soundclick.com/riship
www.myspace.com/rishipmusic
http://riship.xquisitent.com/hfts.html
^ Rishi P & Mnemonic Devize - Heat For The Summer MIXTAPE (FREE D/L)
www.burnproductionz.com/riship
^ Rishi P - Both Sides Of The Coin MIXTAPE (FREE D/L)
Old 02-20-2003, 02:59 PM   #4
a96710
a96710's Avatar
It won't mess up wires but your amp won't perform like it should. Blowing the fuse.....that depends on what size is in the line with the wire now. You wanna get a fuse a lil smaller then the one on the amp so it'll pop that first instead of goin to the amp if anything ever happened
Old 03-08-2003, 03:03 PM   #5
black95gs-t
black95gs-t's Avatar
running wire that is too small is not a very good idea. think of it like trying to drink a milk shake trhough one of those coffee stirring straws. not fun right? you can get some through that thing but you have to work really hard to get it then you eventually say screw it. same thing your amp will try to pull the power it needs through it but it will have to work really hard to get it and it will get pretty hot and loose sound quality not to mention power. and prematurely your amp will say screw it and over heat and die. not fun stuff.
J
LOONEY TUNES!!!!
