Old 02-19-2003, 10:06 PM   #1
civicracer28
Speedometer problems
I have a '94 civic EX 5-speed with a non-working speedometer. It used to work every so often but now its just dead. Tach works, feul gauge works, engine heat gauge works, but no speedometer. Any ideas from anyone would be of much help.
Old 02-19-2003, 10:06 PM   #2
did you check the connections in the back? if that doesnt do it you might have to buy a new cluster...theyre all over ebay
Old 02-19-2003, 10:35 PM   #3
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
whoah...that's like the first time i've read pdiggitydogg say ebay instead of "eGay"
civicracer28: make sure you check the wiring behind the gauge..... its cheaper to do that than buy a whole new cluster..
RICE....is good
Old 02-19-2003, 11:20 PM   #4
crap...typo...eGAY eGay eGay...there problem solved....but yeah definately check the wires first
Old 02-20-2003, 01:20 AM   #5
does it have wires or it's a cable ? that ight have come unplugged. if it's electric look into the vss, but i thibk that should have trown some check engine lights.
