Old 02-19-2003, 08:50 PM   #1
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
E Brake Removal
I'm planning on spicin' up my interior a bit.. i got a 99 Civic EX and i wanted to get an "aftermarket" e-brake.
My question is.. how do you remove it? Thanks
RICE....is good
Old 02-23-2003, 01:33 PM   #2
HondaTypeJ
Ditto! Except I want to do the reverse of what he wants to do. I want to remove this stupid aftermarket Razo e brake that I have on there and go back to stock. I cant figure out how to get it off.
Old 02-23-2003, 06:01 PM   #3
Zexamericano
hack saw....jokin I have no clue. But I would also like to know because I want to paint mine.
Old 02-24-2003, 05:42 PM   #4
eviljayr
i heard you just need to pry it off. Stock slips on really tight and aftmkt is a good question. they could have screwed it on or glued it, sometimes on top of the stock handle so you might have to get a new stock handle if it's got glue and holes in it
Old 02-24-2003, 06:35 PM   #5
Many models need to be sawed off. I'd wait for someone with your model to confirm though.
Old 02-25-2003, 06:01 PM   #6
davidthall55
Okay, so Trevor, how do I get the stock e-brake handle off my Accord?
Old 02-25-2003, 07:44 PM   #7
i think you need to saw it off. i looked at mine and the cars are pretty damn close.
Old 02-25-2003, 08:45 PM   #8
Zexamericano
Damn, I was right and it was a flat out guess...I feel lucky.
Old 03-17-2003, 06:05 PM   #9
jjcivic92
jjcivic92's Avatar
Man, sawing off the e-brake handle? That's crazy. But I mean, I guess you have to do what you have to do. I have a 1992 Honda Civic, would I have to saw that off also?
jjcivic92 is offline   Reply With Quote
Old 04-09-2003, 10:58 PM   #10
kidd_honda
use the mighty flat head screw driver
i changed my e-brake using a flat head screw driver. I sat in the back seat of my car and i pointed the flat head screw driver to the top of the e-brake. Then use all of your might to push forward. Make sure you get a towel or something to cover your shift to not get it scratch. believe me!!!! It came off in 15 mins having 25 tries. Good luck!!!!
Old 04-13-2003, 06:02 PM   #11
LADAownzU
also in terms of sawing it off, if you have a dremel you can saw it "along its length" till it hits the metal part, then simply pry it off
i get the feeling most people think "sawing off" means right at the root LOL,
Old 04-20-2003, 10:39 PM   #12
psh...I changed mine and now Im buying a stock arm to replace the thing (cant get new handle off and I sawed the oe handle)
dont change it...you'll be happier in the long run
Old 05-04-2003, 02:00 PM   #13
sohc_vtec 2NR
just to let everyone know...you just twist of the ebrake handle... that works fors a 99 civic, i don't know about the other cars though...
i asked a car shop around here and i just decided to let everyone know who ever might be interested...
RICE....is good
Old 05-06-2003, 09:48 AM   #14
didnt work on mine...
Old 05-07-2003, 08:44 PM   #15
sohc_vtec 2NR
pdog- how did you get yours off then? the person at the shop said "you have to twist the hell out of it"...
RICE....is good
Old 05-19-2003, 12:08 AM   #16
you'd twist the arm if you did it that way... I cut mine along the sides and then forced it off w/ a big screwdriver and pliers
(sorry it took me so long to repost)
Old 06-03-2003, 10:33 PM   #17
sohc_vtec 2NR
i should prolly just get one of those ebrake "covers" instead of replacing it....
RICE....is good
Old 06-05-2003, 10:54 AM   #18
they make those?
Old 06-16-2003, 01:47 AM   #19
sohc_vtec 2NR
yeah... and to this date the handle is still not willing to cooperate with me...i'd feel horrible to cut it up...
RICE....is good
Old 06-16-2003, 04:23 PM   #20
like i said...leaving it on there would be the best thing...hell Im really glad I got another to replace it (yay oem)
Old 07-09-2003, 06:01 PM   #21
WhiteSleeper
I've tried to twist mine off with no results. Couldn't get it off no matter how hard I tried.
