Old 02-11-2003, 09:20 AM   #1
JamieS697
Taillite prob
my right tail is fogging up and im just wondering is that from a bad seal or wtf if going on??? It hasnt affected the lighting yet so im not sure if i should be worried.
Old 02-11-2003, 09:25 AM   #2
yeah its a bad seal...if you want you could take off the lens and let it sit inside for a while or use a hair dryer on it so all the h2o gets out. then if you want put some silicon all around the edge for a better outer seal, but the back is practiacally open so this probably isnt necessary...just get the water out somehow
Old 02-11-2003, 03:33 PM   #3
that tends to happen with the lower quality altezzas and crap. yeah, just seal it up good with some silicon you can buy anywhere.
I've also heard that drilling a small hole in the bottom of the tail will help this too. I'm pretty sure thats a load of crap, but anyone else heard of that?
Old 02-11-2003, 03:35 PM   #4
Is this a stock light, or an aftermarket setup? Anyway, yeah... dry it out with something and seal it back up.
Old 02-11-2003, 04:26 PM   #5
if you were to drill a hole...which might not be that bad if its on the back...would have to be at the top with some kind of hose thingy like the headlight so the water has a way to get out
Old 02-11-2003, 10:43 PM   #6
JamieS697
altezzas havent had a prob till now f*ckin apc
Old 02-11-2003, 11:51 PM   #7
you should have said it was APC in the 1st place..then we would have all said "Ooohh, yes that is the problem"
Old 02-12-2003, 12:44 AM   #8
lesson #1 of buying cheap crap for your car: good god stay away from APC!!!
Old 02-12-2003, 03:58 AM   #9
Senshi
apc isn't that bad now, i got clear corners from them, not the CLEAR CLEAR EURO ones but the ones that looks kinda like the headlights in detail and they have never had a problem, but i would never get a performance part from them, and if i do get lights from them i would be smart enough to SEAL THEM UP MYSELF before applying
Old 02-12-2003, 10:04 AM   #10
the key to that is "seal them up myself" a person shouldnt have to do that with a good part...
Old 02-12-2003, 10:35 PM   #11
JamieS697
exactly and i bought them b4 i knew how crappy apc was. Now i know so i will make better choices in the future
