Old 02-09-2003, 07:33 PM   #1
VT1-R
Flywheel/Clutch setup for big power
What Flywheel and Clutch setup are you guys running with your big power engines?
What you you recommend for a Turbo B16A with around 550hp?
Old 02-11-2003, 10:21 AM   #2
SthPerformance
I have the ACT extreme pressure plate and 6 puck disc with the Act 8 pound flywheel...
Alot of people use that combo or the Clutchmaster stage 5 kit with the CM flywheel...
Old 02-11-2003, 05:30 PM   #3
Boosted3g
I run the CM stage 5 and a CM flywheel. Id rather have a steel flywheel rather than my aluminum one though. They are better than the aluminum at high horsepower.
