Old 02-06-2003, 06:05 PM   #1
jaywho123
sir help
ok so i'm missing my power steering pressure switch
i know it one end goes here(photo below) but where does the other end go someone please help!!!!
Old 02-07-2003, 12:56 PM   #2
jaywho123
so can on one help or does anyone not want to help
Old 02-07-2003, 01:04 PM   #3
Sorry but Im going to move this to the civic forum also.....get more attention there.....
Old 02-07-2003, 01:17 PM   #4
on my accord one is liked to speed sensors in the tranny if i'm not mistaken.
Old 02-08-2003, 01:51 AM   #5
tooslow91crx
all the power steering pressure switch does is raise idle when you turn a certain amount at idle, like in a parking lot. one end should go in the steering rack and the other end should make it's way to the ecu one way or another. unless it's giving you a check engine light or you're having trouble keeping your engine from stalling when you try to park, i'd say it's really not a big deal
Old 02-09-2003, 12:06 AM   #6
calling out civic addict on this one. he has the same car, only black
Old 02-10-2003, 12:44 AM   #7
jaywho123
its not really a big deal to me it should start warming up soon.
i talked to a honda dealership there serviice tech says it goes from the engine harness to the rack
the car makes a horrible sound when i have no power steering
Old 02-10-2003, 02:15 PM   #8
Horrible.
It sounds like a supercharger!!!
hahahaha
because the oil isn't being pumped through
Old 02-10-2003, 04:21 PM   #9
Heh... I kinda missed this one.
I'll get you a pic when I get home(about .5 hour or so).
Old 02-10-2003, 05:03 PM   #10
jaywho123
sounds good
Old 02-10-2003, 06:27 PM   #11
Sorry for the fuzzy pic. Its like 13 degrees outside.
It should be a wire harness. I'll try to get you a clearer pic. It just has 2 wires coming out of it. I'll look to see where it goes in a bit if you want.
Old 02-10-2003, 06:35 PM   #12
Close up
Old 02-10-2003, 06:36 PM   #13
Where the wire leads to....
Old 02-10-2003, 06:38 PM   #14
Distance shot... The harness leads under the intake manifold.
Old 02-10-2003, 06:39 PM   #15
Hope this helps you out....
-Addict
Old 02-10-2003, 08:35 PM   #16
jaywho123
yeah sorta
you can't see where it leads too?
Old 02-10-2003, 09:45 PM   #17
yeah sorta
I couldn't tell. I'll check it out tomorrow.
Old 02-10-2003, 10:22 PM   #18
jaywho123
sounds good
Old 02-11-2003, 01:15 PM   #19
sounds good
Thanx Addict
Old 02-18-2003, 11:23 PM   #20
tooslow91crx
is it low on ps fluid? is the belt in good shape? the pressure switch shouldn't cause you to lose your power steering, it's just an input to the ecm to control idle speed
Old 02-19-2003, 10:55 AM   #21
yeah but when it's -40 it does
