Old 01-19-2003, 10:58 PM   #1
port and polish
around how much hp would this net me? Im gonna turbo the d16 w/ greddy...eventually and was just concidering the port and polish. I know its not gonna give huge gains but I was still curious. I wouldnt do it myself, theres a local shop that does it for $16/port
Old 01-20-2003, 03:33 AM   #2
flit
To quote somebody off of AIM (in reference to honduhs):
RainbowBrite6484: Yeah...who spends 20,000 on just modifications and the car is still heavy and slow
AND SHE'S A CHICK AND KNOWS WHAT'S SUP.
Old 01-20-2003, 10:14 AM   #3
Wtf...ok that has nothing to do w/ anything what so ever...if you’re going to be an ass...just f*ck off. Oh, and if you’re saying that civics are heavy...you’ve obviously have never even seen one...so you and your oblivious friend clearly don’t "know whats sup"...which isn’t phonetically correct anyways
Old 01-20-2003, 12:00 PM   #4
it all depends on how good of a job they do. i never heard any specific numbers, but keep in mind that the job is gonna cost a lot more than port and polish. if u remove the head make sure you get a better cam and some other head goodies
Old 01-20-2003, 01:33 PM   #5
I was concidering a new camshaft and adj gear too...maybe some other crap...but farther down the road
Old 01-20-2003, 07:56 PM   #6
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
pdiggitydogg, you should buy one of those gtech thingys and do the port and polish, then tell us your results...
RICE....is good
Old 01-20-2003, 08:13 PM   #7
lol gtech...yeah...those work ...trust me ive used them, it said a 2001 mustang gt had 115hp...we did 10 tests on it then moved onto a 2nd gen eclipse and according to the gtech it had 240hp...a stock eclipse...not even turbo...so I dont trust em at all
Old 01-20-2003, 08:25 PM   #8
sohc_vtec 2NR
thanks, you just saved me from shellin' out 250 for one of those things...
RICE....is good
Old 01-21-2003, 10:23 AM   #9
02CiviC
huh?! this girl doesnt even sound like she knows the sky is up.
heavy and slow? what is she modifing, an 18 wheeler?
Old 01-22-2003, 11:22 AM   #10
shadowracer
Believe me when I say it Honda knows what they're doing. If you are going to get the port and polish done just have them port match the intake mani to the head and the exhaust mani to the head. Honda heads are very high flow. Regarding the came stick with the stock one and get a vtec controller. To much valve overlap can cause a lot of headaches. The only cams I recommend are Skunk2, reason being is because they try to match the manufacturing process that honda has. I think they are coming out with a turbo friendly cam soon. I'd also recommed spoon cams and mugen ones but i don't think they make turbo friendly SOHC cams.
Just a lil reference a friend of mine and myself put togther a d16z6 w/ 9.0:1 comp pistons and rods in a stock block w/ a blockgaurd and have run low 13's to high 12 sec 1/4mile time @ 5psi boost. All this under 6000.00 including the car (94 honda civic ex) Skip the greedy kit put it together yourself a lil research and some know how with proper tuning go along way.
D-series, my weapon of choice!
shadowracer is offline   Reply With Quote
Old 01-22-2003, 11:30 AM   #11
The times are consistent though on a flat surface and they let you know if your mods made an improvement. The hp readings are very hard to get.
