Old 01-19-2003, 10:47 AM   #1
calls97
is it worth it
to hook up my stock engine in my 97 civic or save my money until I can get a new motor or start on the out side and work in thanks
sam
Old 01-19-2003, 11:27 AM   #2
oc civic
hoiw realistic is the thought of a swap.. can you REALLY afford it??
if not get a d16y8 head, bolt ons and a small shot, and it should be decently quick...
Old 01-19-2003, 12:48 PM   #3
what are your goals ? drag, auto-x, rallying ?
Old 01-19-2003, 01:47 PM   #4
calls97
my goals are mostley drag and show
Old 01-19-2003, 02:41 PM   #5
oc civic
Re: is it worth it
sam
Old 01-19-2003, 06:25 PM   #6
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
how much miles does ur motor have right now? if its up there..then a swap would probably suit you better, if not, why waste a perfectly good engine? an EX head swap that oc mentioned should be your first step..that is if you keep your current powerplant... don't forget that money is an issue also.
RICE....is good
Old 01-19-2003, 09:01 PM   #7
calls97
I have 130000 miles on it so I dont know and where could i find the new head
Old 01-19-2003, 09:27 PM   #8
sohc_vtec 2NR
there's a lot of "head" to be found on ebay .. i believe it is also called a "mini me" swap..
are you planning on goin' forced induction with your car? if you are then i'd save up for a new motor, since rebuilding an older motor would not be as "cost-effective" compared to an engine swap..
RICE....is good
Old 01-19-2003, 10:33 PM   #9
definately egay has several heads as of now
Old 01-19-2003, 10:34 PM   #10
calls97
ok I will look for the head and I know I would like to go forced induction so I will look
Old 01-20-2003, 01:19 PM   #11
96civicex
is it possible to put an si head on an ex and if so is it worth it
96civicex is offline   Reply With Quote
Old 01-20-2003, 01:23 PM   #12
you could put a older si (92- series) head on..but not a 99-00 head because its dohc
