Old 01-16-2003, 08:30 PM   #1
Grip72
Grip72's Avatar
Tell Tale signs clutch is gone??
Ok my car is not actign weird of anythign but it feels like i have NO clutch resistance or pressure or wahtever u wanna call it. I was just wondering wahta re the usual signs or symptons to know when one's clutch is gone and needs to be replaced. The car is not handling or acting or anything differently. It is drivign great, but i'm just curious...
Old 01-16-2003, 08:33 PM   #2
Sounds like the master or slave cylinders are leaking or are low on fluid.
If your clutch is going it will slip.
Old 01-16-2003, 08:42 PM   #3
Grip72
Grip72's Avatar
...slip? like the engine will rev higher but u wont' pick up speed or what do u mean?
The master and slave cylinders looked ok...i'll keep an eye on them buggers tho..thx
Old 01-16-2003, 08:54 PM   #4
Yeah, slip is when you pop the clutch and it revs but you don't go as fast as you could.
If you're losing pressure, its most likely the cylinders though.
Old 01-16-2003, 09:07 PM   #5
good way to check slipage is to go like 30 and then drop it into 5th...if the rpms rise but you dont go any faster...your clutch is slippin...
id check the fluid level first and then try this...just because you can do it w/o goin anywhere...but if its low...fill it and then still try the driving thing...just to be sure you dont have more than 1 problem
