Old 01-16-2003, 04:17 AM   #1
yelizardking
blown engine?
hey what exacly happens when ou "blow up" your engine because of high revving?
Old 01-22-2003, 12:27 AM   #2
tooslow91crx
there's a lot of ways to blow an engine. when you over-rev, generally, you break something kind of important like connecting rods or wrist pins. that's why ecu's have rev-limitters. as long as you keep your rev limitter where it's supposed to be, and you don't downshift crazy, like into 2nd gear at 90 mph, you should be okay.
Old 01-23-2003, 05:03 AM   #3
yelizardking
what are other ways you can blow your engine?
Old 01-23-2003, 08:39 AM   #4
habe a rod trown thru the block, crack a piston, break the crank. aww the possibilities
Old 02-03-2003, 10:01 PM   #5
armyguy5
3rd Gear
armyguy5's Avatar
threw a rod in my 91 lumina in the middle of nebraska =(
chris
Old 02-04-2003, 12:03 AM   #6
Azkikr111
haha...............sigh............yeah......:para noid:
Old 02-04-2003, 08:29 AM   #7
Is this a "hypothetical" question?
Old 02-05-2003, 11:04 PM   #8
Turbo_LS_Hatch
I spun 3 bearings not too long ago.....maybe 3 weeks ago. Trying to blow the engine are we?
Old 02-11-2003, 12:03 AM   #9
Damaclese
Not really blowing it, but lack of oil = bad. One night I was driving home from work and part of the road was tore up due to raod construction. I hit a pothole and didn't think much of it. Well the next day while driving around the car just died. Come to find out, hitting the pothole had put a hole in my oil pan and it all leaked out overnight. Like I said, it's not blowing it, but the block did melt together with the rest of the engine. Kinda the same effect.
Old 02-11-2003, 01:03 AM   #10
Turbo_LS_Hatch
I spun the bearing because of an oil pump failure.
You're oil light didn't come on?
Old 02-19-2003, 12:48 PM   #11
Zexamericano
Ive spun bearings, thrown rods, blown turbos, blown headgaskets, burnt valves, they all cause your car to run like crap, and your wallet to thin out. They also hold up my future mod plans, that sux.
