Old 01-12-2003, 09:56 PM   #1
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
friggen computer
Damn thing wont boot up.
Heres the thing, a couple months ago my powersupply went and it kinda messed up my computer. It fried my voodoo card and HD. So, I asked a friend to give me one, and he did. I started having problems with it, (boot up.. as in it will not detect 'primary slave' or whatever) but they went away after a few weeks. Just recently they started back up again, and I figured it was the HD, but I guess not because I just bought a 5400 IBM 40 gig last night. (fricken expensive) anyways, I havent got the slightest idea for waht is wrong with it? Could it be the cables got pulled or something? All the connections are tight, but maybe there is something wrong with the cable itself...
It basiclaly says:
Primary Slave: !#_!&)*120380200100283!@)#*@)#&4
or some scrambled message like that. And it isnt always consistant.... its REALLY jacked up.
I'm thinking its the motherboard, because its the only piece on this computer that I havent touched yet. If it isnt' I guess its the cable.
Old 01-12-2003, 11:21 PM   #2
Is your new HDD set to master? Did you try clearing the BIOS when you had problems?
Old 01-13-2003, 12:02 AM   #3
also make sure the cables are plugged in right.
Old 01-13-2003, 12:50 AM   #4
TweaK
Red line
I dont know if you fixed this but ..If now you ahve 2 hard drive..Keep the one with windows on it at the very end of the ide cable and the the second one ont he plug in the middle..and make sure the red line on the ide cable is on the right hand side
Old 01-13-2003, 01:42 AM   #5
TeriyakiBroccoli
5th Gear
Accord: How would I clear my BIOS? I have it set (first boot device) on HDD-O.
Hondaman: yep they are
Tweak: I swapped Hard drives :( so theres only 1 in there right now. Im so pissed... I want to get a new puter.
everyone loves the turbizzim.
Old 01-13-2003, 01:43 AM   #6
TeriyakiBroccoli
5th Gear
Its such a piece of shit, I want to piss on it with the power on and just watch it fry.
Old 01-13-2003, 02:43 AM   #7
Ahaha, just like pissing on an electric fence Ouch.
Old 01-13-2003, 03:51 AM   #8
TeriyakiBroccoli
5th Gear
I'll stand a distance offf.
Ok new update.
This is how my cord was mapped from my mobo.
It has 2 "ports" or whatever you'd like to call them one was plugged into my HD and one was plugged into my CD rom. I plugged the one from my CD rom into my HD (its at the end of the cord) and it booted up fine.... I don't know how long this is going to last however.
Old 01-13-2003, 03:55 AM   #9
Don't ever put your HD and CD on the same IDE channel. There are two IDE channels on your mobo. Put HDDs on 1 and CD drives on the other. Otherwise your HDD will operate at the speed of your CD (to keep it simple).
Old 01-13-2003, 04:27 AM   #10
TeriyakiBroccoli
5th Gear
I dont have any more little things to plug into my CD thing tho. the one off my HD line is the only one left.
Old 01-13-2003, 04:37 AM   #11
Trace the HD IDE cable to the motherboard. It is plugged in to an IDE slot, probably IDE 0. Next to that, there should be an open IDE 1. If its not open, what's in it? Do you just not have a cable?
Old 01-13-2003, 09:22 AM   #12
I would atleast disconnect the CD drive just to make sure that isnt the culprit anyhow.
But, 94_Accords right.. You should have the CD and HDD plugged into the same ribbon.
Old 01-13-2003, 03:34 PM   #13
TeriyakiBroccoli
5th Gear
looks like i got 3 slots, the HD one goes on the far left and the other 2 are occupied (they go to my dvd player cd burner, and floppy)
Old 01-13-2003, 03:47 PM   #14
do you really need a DVD player, CD, and CD burner?
Old 01-13-2003, 05:18 PM   #15
TeriyakiBroccoli
5th Gear
Why not :( Can i buy a special cable that has 3 little plugs ? so my cd burner and dvd would all go on one cable thing
Old 01-13-2003, 06:31 PM   #16
No, I think you're ok. you should have the HDD alone, the dvd and cd on the 2nd channel, and the floppy has its own channel that can't be shared with the IDEs.
Old 01-13-2003, 11:09 PM   #17
TeriyakiBroccoli
5th Gear
kk
my computer seems to be working flawlessly now.
Anybody play cs?
I finally got mine to work except my framerate is very jumpy. Whenever Im shooting some one, or theres a really close battle, my frame rate shoots down to about 40 from 70 fps.
