Old 01-07-2003, 10:24 AM   #1
Trick computer mods
Okay.. This is for the Geekiest of geeks..
Is there anyone here that has a tricked out computer? If so, post some pics if you have some.
I dont yet. I want to though.
Old 01-07-2003, 12:01 PM   #2
what do u mean by tricking a computer ?
Old 01-07-2003, 12:16 PM   #3
clear cases, cathode lights... stuff like that right?
Old 01-07-2003, 01:30 PM   #4
Yeah, check out this place.. There is some insane stuff on here!
http://www.hitechmods.com/
Old 01-07-2003, 08:11 PM   #5
Quevv
"The Ice Box" is awesome!
Old 01-07-2003, 08:16 PM   #6
I'm using a pre-modded right now, but my next case (coming in a couple of days) will be "demelized" and fully watercooled
Old 01-07-2003, 08:32 PM   #7
Kyle
elyK
damn...those are sweet
IGNORE THE FACTS
EXPLORE THE TRUTH
Old 01-07-2003, 11:07 PM   #8
munky185
I custom built my watercooled pc setup. I ordered parts, pieced togeter the computer, then ordered the following parts and composed a watercooling loop (helps with overclocking cpu's because cooler cpu = more stable cpu):
-Eheim 1048 Pump
-Tygon R-3603 Tubing
-Dtek Pro Core Radiator (essentially a automotive heatercore with 2 barbs welded on)
-Dtek TC-4 Waterblock (attaches where your typical cpu heatsink/fan would go and water flows through it to cool you cpu)
-Miscellaneous fans
As soon as I take some pictures I'll post them on here for anyone who would like to see it. This is my other hobby lol. Right now my Athlon XP2000+ is overclocked from 1.66Ghz to 1.85Ghz. I also cut a hole in the front of the case for an 120mm fan and cut a good bit of the side of the case out and installed a window. A blacklight inside the case illuminates the water in my watercooling setup because I've added a couple of drops of UV reactive NAPA radiator dye. Also all my cables are UV reactive. Looks pretty sweet when the lights are off and the blacklight is on.
Old 01-07-2003, 11:15 PM   #9
i wonder how can i put those black lights in my laptop
Old 01-07-2003, 11:38 PM   #10
-Eheim 1048 Pump
-Miscellaneous fans
I have a similar setup. :
Eheim 1250
Tygon 3603
Dtek rad with dual shrouds
2 120mm deltas
DangerDen Maze 3
no res, opted for a t line instead.
Old 01-08-2003, 08:00 AM   #11
Please do, it sounds sweet!
Id like to watercool but the whole Idea of water and electricity kinda scares me.
How much does a watercooled setup like that cost if you dont mind me asking.
Old 01-08-2003, 01:04 PM   #12
Eheim 1250 - 60
Tygon (10ft) - 20ish (depends on thickness of sidewall)
Dtek rad - 50
shrouds - 40 (or build your own)
2 delta fans - 22
maze 3 - ~55
misc hardware - 5-10
__________________-
~250, but you can EASILY build a setup cheaper than that. Go to the junkyard, pull a heater core, solder barbs onto it, or get one for $16 @ napa & solder. Shrouds you could easily make, etc.
Old 01-09-2003, 08:00 AM   #13
Thats not to bad..
Old 01-09-2003, 12:16 PM   #14
munky185
Eheim 1250
Tygon 3603
2 120mm deltas
DangerDen Maze 3
Phew, those deltas are loud. My roomate has a Vantec 80mm Tornado cooling his XP2000+ and it's quite the noisemaker. We don't really mind it though. The sounds of fans put me to sleep. My 120mm intake fan is the loudest thing on my computer, but the sound it produces is of a much lower frequency, so it's pretty bearable. I have a T-line in mine also, but I couldn't fit dual shrouds due to the hellacious size of my GF4 Ti4400. I really wanted dual shrouds too.
Old 01-09-2003, 12:19 PM   #15
munky185
I thought that at first too but actually if you take time to put together a good system and use metal hose clamps to secure the tubing onto the barbs, then leaks don't happen very much at all, if any. I've had my system built for almost a year now, and I haven't had a single leak yet.
Old 01-09-2003, 02:49 PM   #16
The deltas aren't that bad, they are a step down from the highest CFM 120s. I have them on a rheostat to turn them down anyway.... only affects temps by about 1-2'C. Besides, 120s are a lower pitches noise. More like a large house fan.
I have a tornado on one of my boxes right now and its killing me. The box is on the desk next to me and I hope to get rid of that fan soon.
Old 01-09-2003, 04:30 PM   #17
what is a good quiet fan... since i run my computer 24/7 i think i should throw another fan in.
Old 01-09-2003, 06:19 PM   #18
munky185
Here's a link to where you can get some good computer fans. If you're looking for ultra quiet, I suggest the Vantec Stealth series (I'm assuming you need 860mm x 25mm size fan(s)). Bear in mind that the quieter the fan, the lower the amount of air it moves (usually). The decibal rating (dB) is provided in the description rating for each fan, so you decide exactly how quiet you want. Also the cfm rating is provided (cubic feet of air moved per minute).
Click here.
Also, if you get a fan with a 3 pin connector, you'll need a 3 to 4 pin adapter to be able to plug it into the molex connectors that your PSU supplies.
The adapter is found here.
Hope that helps a bit. You can also find fans at newegg, among many other places on the net.
Old 01-09-2003, 06:28 PM   #19
SVC is an excellent company to order from. I've ordered a couple of times from them. The Stealths are nice, and so are the Panaflo L1As if you're looking for quietness.
Old 01-09-2003, 10:04 PM   #20
when i pick up my new vid card for my rig, wc'ing will be happening, yes it will.
gonna pick up a new case first too and give this one to my gf so when she finally lets me build her a comp that doesnt suck - she'll have my nifty case
Old 01-10-2003, 10:56 PM   #21
Shot 2 Hel
i was looking into building a computer a while bak but im cheap, and broke (go together, no) so i changed my mind. If you get TechTV watch the screen savers there is a guy on there named Yoshi who is like a computer buiding god. He made a mouse with a cooling fan. It was awesome.
Old 01-12-2003, 09:41 PM   #22
building computers...you can get something cheaper and better than a comp @ best buy or circuit shitty.
Old 01-13-2003, 01:41 PM   #23
Hmmm.. I don't have any pics of mine yet. Its got 'stuff' in it though.
Old 01-13-2003, 01:44 PM   #24
Though Ive seen it.. Post some pics slacker!
