Old 01-04-2003, 03:21 PM   #1
insomniac_91
spark plug
ok well I just changed my spark plugs, rotor and cap...It was having a fireback kinda feeling when I let the clucth go and and gas go.. I just test drived it and it runs alot better no fireback as of yet....Well here is the dilemna I found oil on one on the plugs and wires anyone know the problem. Seems costly....
help please any suggestions will be appreciated
Thanx in advance
Old 01-04-2003, 04:02 PM   #2
is it the second cylinder from the timing belt ? it's not that expensive. you are looking at $45 for the parts and half a day labor on the car if u do it yourself. all the rocker arm assembly is gotta go out to replace the gasket
here is like what you have to go thru
valve cover off
rocker arm assembly off
head without rocker arm assembly
it's a pain in the rear and after all the work you need to redo the valve adjustament
Old 01-05-2003, 12:17 AM   #3
insomniac_91
thanx for the help Hondamaniac, but it was the 1st cylinder on the left next to the dist. cap. someone told me that I need to change my valve cover gasket and get some spark plug seals.. What you think sound bout right.
Old 01-05-2003, 12:26 AM   #4
yup it sounds right. but it's the lower gasket that is leaking not the one between the cover and the assembly.
Old 01-05-2003, 12:30 AM   #5
insomniac_91
All right thanx I appreciate the help good lookin out...
