Old 12-27-2002, 12:03 AM   #1
guprestyle
Kicker installation
aiite guys let me kno if this will work..
i have a 300x2 kicker amp at 4 ohm
i have a 15L7 4 ohm kicker square dvc
I was wondering if it would sound good to run one channel to one voice coil and one channel to the other. would both coils get the same frequency, and would it sound fine? The reason i have to do it this way is becuz the sub is 4 ohm, so if i break it down to a 2 ohm, then my amp will only run 175 x 4, but i want to run it at 4 ohm so i can get 300 x 2. the only way to do this with this amp is to run each coil separately at 4 ohm, so basically im going to treat the single dvc sub as 2 different subs... what do u guys think? i talked to someone and they said they did it and it sounded the same both ways.. but someone else said that one coil would be pushing different and more or less bass than the other????
help me out plzz
02coupev6
