Old 12-18-2002, 02:00 PM   #1
installing my coilovers
I was trying to piece together my illumina Rs today and I have no directions or part identification sheet...i need help...
what order do the parts go in on the shock???? I took 2 pics of how i think they might go...but im really lost...help
Oh and I know that some of the OE parts gotta go back on too
(I've got 4 of the fat washers)
Old 12-18-2002, 02:02 PM   #2
sorry..i dont know how to post multiple pics...
Old 12-18-2002, 02:03 PM   #3
are either of these right?
...probably not...
Old 12-18-2002, 02:16 PM   #4
oc civic
how ****ing complicated that sucks man... i would look and see if they have instructions on a website or something... i can't remember exactly how they go and dont want to stear you in the wrong direction..
Old 12-18-2002, 07:29 PM   #5
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
Re: sorry..i dont know how to post multiple pics...
Ok,
On your black piece that rides on top of the strut tower, (the part that bolts to your car...), the 2 rubber washers should sit in there. One on top, one on the bottom. And they should be pointed upward. Then, the little hollow (silver) metal tube clylinder should sit in the hole. Then, there should be another flat washer that sits on top of the rubber piece (top piece), then the brass piece goes on, with the lip pointed upward. Then, the screw should go on, but not too tight.
Old 12-18-2002, 07:30 PM   #6
TeriyakiBroccoli
5th Gear
The manual doesn't come with anything? I could be wrong, but that is how my shock assembly came apart (OEM.)
everyone loves the turbizzim.
Old 12-18-2002, 09:22 PM   #7
did u pay attention while taking OEMS apart ? the should go in the same way.
Old 12-18-2002, 11:17 PM   #8
i havent disassembled the oe ones yet i just wanted to put these together ahead of time
Old 12-18-2002, 11:53 PM   #9
well on the strut is should be the bump stop, then a special washer on top of it, then a big washer, one of the black bushings facing downward, the upper spring seat, the other black bushing, the upper washer and the nut. i hope this helps.
Old 12-19-2002, 12:09 AM   #10
This? 1 black rubber downward on the bumpstop, the big bronze washer next and the other black rubber on top the metal tue insde the 2nd black and the fat washer on top of the tube...nut on the top
If this isnt it, I'll just try and figure it out from the OE ones when I do it
Old 12-19-2002, 01:20 AM   #11
nope !!
ok i'll go from the top
Nut
Bronze Washer
Rubber Bushing
Upper spring Seat
Rubber bushing
Washer (comes from the stock shock assembly)
Dust cover (comes from stock assembly)
Washer it fill that chage in thickness of the shock(comes from the stock assembly)
Bump stop
Old 12-19-2002, 01:26 AM   #12
here is a pic i found in one of my accord manuals. i'm installing my coilovers now and they are coming out quite great. i really followed the instructions in the book
and this is the pic of theassembly...
Old 12-19-2002, 09:10 AM   #13
phat yo
teriyaki helped me out last night too. really appreciate all the help. i figured it out now,
thanks all
(I really gotta get a helms cause this haynes description is shizit)
Old 12-19-2002, 10:08 AM   #14
TeriyakiBroccoli
5th Gear
I have the haynes as well. The directions for uninstalling the door panel is really gay. On section 16, it says something like take of this, take off that, then go to section 18 to see how to take of this. Then in section 18 it says, take of this, take off that, then go to section 16 to take off this....
Old 12-19-2002, 10:13 AM   #15
Ha ha ha mine does the same thing for a lot of things but it helped in time of need
Old 12-19-2002, 12:13 PM   #16
ShagginJet
ShagginJet's Avatar
I have the 88-91 civic manual if you want a page scanned out of that...
RECENTLY UPDATED!!! 5-20-04
