Closed Thread
Old 10-30-2001, 10:45 PM   #1
Post 99-00 Civic Si Front "H" Emblem Removal
by Civic_Addict
This modification is relatively easy. But as with any do it yourself project it requires patience.
I take no responsibility for any damages that may occur. The instructions are provided as a guide. Also you may have to cut and paste the links below into a new browser window to view them.
Tools Required
10mm socket or wrench
#2 Phillips screwdriver
Flat-head screwdriver
Step One:
Open your hood. Remove the five plastics "pops" (call them what you like) that are in the front of the car near the upper grill.
Step One
Step Two:
Remove the Phillips screws from each side of the car(two total). These are located in the wheel well, right at the "seam" where the bumper & fender meet.
Step Two
Step Three:
Remove the Phillips screws from underneath the bumper. They are located near the curve in the bumper(under side), slightly behind the front lip.
Step Three
Step Four:
Remove the two 10mm bolts from the under side of the car. These should be fairly easy to spot.
Step Four
Step Five:
Now gently pull the bumper forward. You may need to push down near the area where you removed the screws in Step Two. It should slide right off. Be careful not to scratch it.
Step Five
Step Six:
Locate the three Phillips screws behind the "H". Remove them.
Step Six
Now re-assemble the bumper and step to admire your handy work.
What it looks like completed
Addict is offline
Closed Thread
