Old 12-11-2002, 12:51 AM   #1
97CivicBoy
Need help on installing a bass tube.......
I recently purchased a bazooka 8" bass tube to add to my sound system...does anyone know how I can install it myself...i have a 97 civic sedan...i kno you must run the set of wires from the batter to the back...can someone please post me step by step instructions.
thanx
Old 12-11-2002, 05:57 PM   #2
styldaccordngly
well we need to know if you got an aftermarket radio, or if your still factory.. anyhow..
i wanna say the yellow wire goes to the battery, im not certain on the color tho (your best bet is to find a rubber grommit somewhere under the divers dash) .. blue will go to your switched +12v, or your 'amp turn-on lead' on the back of your radio, and also youll need to run a set of rca's from behind your radio to the tube..
if your useing the factory radio, you need to buy a high-to-low converter, basically itll attach to your rear deck speakers and take the hi signals your factory radio is putting out, and convert the signal to a lo signal (rca)..
Old 12-11-2002, 09:03 PM   #3
97CivicBoy
Yes, I have a an aftermarket pioneer headunit...could you now tell me step by step.
thank u
