Go Back   HSTuners > The Lounge Area > Kill Stories
Closed Thread
Old 04-05-2003, 05:56 PM   #41
Originally posted by JMAXIMA
don't make assumptions you can base on fact. i'm not saying its not possible with a civic... but is there someone on this forum that has a similar set up? but the only real problem i have with this is i doubt you could run that much boost and spray on stock internals and tranny. how much power can you guys run before you start breaking gears and rods?
Wasn't making an assumption. I was just saying that its not an amazing feat. I'm sure there's plenty of 5.0L stangs that could pull that off. Or even LS1's. Regardless.
A 6 cylinder in general can hold more power than a 4 cylinder. I don't know the utmost limit for the Honda engines and I'm not rich enough to try & find it out.
A Civic (D Series) can hold ~80hp additional without any mods. A Civic (B Series) can hold ~100-125 additonal without mods. I'm not sure what the Prelude can handle. I imagine its similar to the B series.
Then again the cost of a new Maxima($27-29000) vs. a new Civic Si($19000), you should get a faster car. I'm not bashing Maximas at all. I think they look good. I've never had a chance to drive one so I can't say anything about how they feel.
Addict is offline
Old 04-05-2003, 05:57 PM   #42
MaxOwner
if you guys were wondering more about the car that ONLY ran 11.9.. sorry for the thread jack
he dyno'd 428.16 hp - 379.33 tq - 1998 5spd
Mods List
Vortech V1 Super Charger
Vortech 2.62" Pulley, 15psi Peak at Redline
Vortech FMU w/3:1 Calibration Disc and Boost Bleeder Valve
Vortech Mondo Blow Off Valve
Nissan 300ZX TT 370cc Injectors
70mm Throttle Body from 3.5L Pathfinder
Bored and Port Matched Intake Manifold TB Port
Custom 3" Super Charger Cross Over Pipe
Custom 3.5" Mandrel Bent Cold Air Intake for SC with K&N Filter
Middle East Variable Intake Manifold (ME/VI)
G-Force ECU Modified for Normally Asperated Performance & Stock Injectors
J&S Electronics Utlra SafeGuard Ignition Controller
Fields Hyper R Boxer Series Air Fuel Controller
Water Alchahol Injection from 9psig up 50% Water/50% Denatured Alch.
Nitrous Oxide Systems 35HP Dry Nitrous System, 2deg Ignition Retard
Nitrous Oxide Systems Bottle Heater
Warpspeed 3" Y Pipe Wrapped with Thermo-Tech Exhaust Wrap
3" Test Pipe, Wrapped with Thermo-Tech Exhaust Wrap
Warpspeed 3" B-Pipe with Resonator
3" Magnaflow SS Straight Through Muffler
SMC Short Shifter
Clutchnet.com Six Puck Sprung Hub Clutch and Heavy Duty Pressure Plate
Place Racing Urethane Front and Rear Motor Mounts
Walbro GSS342 255lph High Pressure In Tank Fuel Pump
NGK BKR6E V Power Copper Spark Plugs, 1-Steps Colder Than Stock. 0.030" Gap
Spark Plugs Are Indexed Using Moroso Indexing Washers
Harlen Components RPM Switch (For ME/VI Valve Control)
Harlen Components Window Switch (For Nitrous Control)
Autometer Dual Pillar Mount Gauge Pod
APEXi Electronic EGT Gauge (Pillar Mounted)
Autometer 0-100psi Sport Comp Full Sweep Electric Fuel Pressure Gauge (Pillar Mounted)
J&S Electronics Knock Monitor Gauge w/ Air to Fuel Ratio (Pillar Mounted)
Custom 3 Gauge DIN Mount
Autometer Sport Comp 30hg to 20psi Vacuum/Boost Gauge (DIN Mounted)
Autometer Sport Comp Mechanical Oil Pressure Gauge (DIN Mounted)
Autometer Sport Comp Electric Oil Temp Gauge (DIN Mounted)
Perma-Cool Oil Cooler
16psi Radiator Cap
Brembo Cross Drilled and Slotted Front Rotors
Stillen Cross Drilled Rear Rotors
Porterfield R4-S Front & Rear Brake Pads
Goodridge SS Braided Brake Lines
Generic Front Strut Tower Tie Bar
ADCO Rear Sway Bar
Eibach Springs
KYB ABX Struts & Shocks
Quaife ATB Differential
Redline MT90 Gear Oil
Redline 10-W30 Motor Oil
16x8 Mazda RX-7 rims (16lbs)
225x50-15 Dunlop SP5000
15x7 Kosei K1 Racing Wheels (14lbs) (For Track Use)
M&H 24.5x8.5x15 Drag Slicks (For Track Use)
Old 04-05-2003, 06:02 PM   #43
MaxOwner
5.0L vs 3.0L quite a bit difference huh?
so in your theory.. an 8 cyl can hold more power than a 6 cyl so just as its not fair to compare a Maxima vs a Civic, its not fair to compare a LS1 with a Maxima.
that faster car comment is not neccesary.. i am not even going to start comparing civic's and maxima's .. because thats a waste of my time
Old 04-05-2003, 06:20 PM   #44
JMAXIMA
i think we've disrupted their forum enough...lol
Old 04-05-2003, 06:21 PM   #45
So is 1.6L and 3.0L....
Exactly. A Maxima can hold more power.
Yours & mine both. I was just stating the facts on pricing.
Addict is offline
Old 04-05-2003, 06:26 PM   #46
MaxOwner
i don't know where this engine comparision came from. You stated that you could make a 4 second difference with 15 PSI and Spray. I meerly asked you to prove it or show proof of it. If you are unable to do so just say it, thats all.
thats your opinion. The 2.6L engine in the Skyline can hold more power than the maxima. Same goes for the 2.0L Motor in the Sentra SE-R.
The 3.0L stock engine in the Supra also holds more power than a stock 5.0L engine in a stang
That maxima you are ragging on cost $8,000 now. It cost way less than what your 2000 Civic SI cost at this point.
Maxima's are not made for speed. They are 4 door luxury Cars. In any case. A 2003 6spd Maxima runs low 14's stock and the 2003 Civic SI runs mid 15's stock. If you wanted to quote numbers
Old 04-05-2003, 06:30 PM   #47
ford50forlife
ford50forlife's Avatar
How many cars you know drop 4 secs on no engine work stock transmission w/ supercharger and 35 shot of Nitrous?
the slower a car is the more time it drops per mods....
if you put a k+n filter on let say a 1988 cherokee it would RESPOND better considering its a 17 second vehicle then lets say a s2000 as far gain in times...
2640lbs with full tank minus me w/ 302cid
check out the crustang and 88 cherokee @
www.cardomain.com/id/ford50forlife
ford50forlife is offline
Old 04-05-2003, 06:32 PM   #48
MaxOwner
what in Gods name are you talking about?
do you have any dyno proof of what you are talking?
Old 04-05-2003, 06:35 PM   #49
ford50forlife
Mods List
SMC Short Shifter
16psi Radiator Cap
ADCO Rear Sway Bar
Eibach Springs
yes we are saying ONLY 11.9
look at the mod list doesnt matter about only 15psi and 35 shot... the amount spent could get just about any car into the freaking 8's
Old 04-05-2003, 06:36 PM   #50
ford50forlife
nm you drive the superior vehicle, im out for this thread, im not gonna sit here and argue with little 2 year olds that mommy probably bought them there cars..... im going out, its friday night for god sakes...
Old 04-05-2003, 06:37 PM   #51
MaxOwner
yes we all know it doesn't take much to make a fox body in 8's
I could use my tax return and get a fox body into 8's..
the point is.. the car is on stock internals and stock transmission.
i notice that you are in Connecticut? where are you located?
yes we are saying [BOLD]ONLY 11.9[/BOLD]
Old 04-05-2003, 06:39 PM   #52
MaxOwner
i have been nothing but mature and respectful to all the members in this thread.
your comment of 2 year olds was not neccessary.
anyway.. since my mommy bought me my car.. care to meet up in CT some where? to see how my mom's car does?
and today is Saturday, not Friday
Old 04-05-2003, 06:45 PM   #53
ford50forlife
one more thing before i go.....
thats where it stemmed from
ahhh the wonders of dohc and forced induction..... great comparison...
so what? my car costs 2500 dollars total with 20mpg full power options and 105mph traps.... does that make it any better? no so stop fighting a MOOT POINT
taking a 2003 max's best time vs. an average civic si's time.... like every other "thread jack" you people always seem to make it out to be that your cars are so superior when you are just taking the opposite ends of the spectrum and colliding
it doesnt matter though.... no matter what times the pull on the track via prep/ pro driver/ full gutted, whatever the case may be they are far from impressive straightline.
Old 04-05-2003, 06:47 PM   #54
ford50forlife
sure, im putting my car back together now after some winter maintence, im sure your not scared of a bolton 5.0 with stock heads and stock cam right? bring all your boys cars you know.... roll stop you choose.
and yes i cant believe i forgot the damn day
Old 04-05-2003, 06:47 PM   #55
MaxOwner
you know i am only 20 mins from trumbull..
Old 04-05-2003, 06:49 PM   #56
MaxOwner
i don't need to bring anyone's car but my own. you let me know when your car is back together. we can get it all on camera.
email me @ dougpcs_2000@yahoo.com when you are ready.
Old 04-05-2003, 06:51 PM   #57
MaxOwner
oh btw.. my car is a bit ricey.. i hope you don't mind.
Old 04-05-2003, 06:59 PM   #58
ford50forlife
dont matter but itll take a lot more than exhaust and a 100 shot to run with me, if you want i can arrange something with my boys stock 96 cobra if you want ahead of time before we run it, (actually i want to see somebody beat this kid because hes a bit cocky since my cars been down)
hit me up online my sn is DAEVOLUTION on aol and maybe on wednesday we can set a race up.
Old 04-05-2003, 06:59 PM   #59
About damn time. SOMEONE PLEASE TAPE THIS.
Ahh what am I saying. Most of the challenges issued on web boards never end up working out...:o
Addict is offline
Old 04-05-2003, 07:01 PM   #60
ford50forlife
oh really
me vs. svt cobra on this board
this is how i met dave lol
Old 04-05-2003, 07:03 PM   #61
oh really
But no video!! I wanna see it.
Addict is offline
Old 04-05-2003, 07:08 PM   #62
MaxOwner
i am still doing winter maintenance too.. wens is definately out the question. Would have to be early May or something if you dont' mind. Gives me sometime to install my Boost Controller and the S-AFC dialed in correctly.
if you can't wait, you can't wait.
Old 04-06-2003, 01:43 AM   #63
MAXIMA95SE
http://www.vqpower.com/v2/modules.ph...p=getit&lid=89
Old 04-06-2003, 03:31 AM   #64
Can't see much. Doesn't sound like either one were trying very hard.
Addict is offline
Old 04-06-2003, 10:58 AM   #65
MAXIMA95SE
Old 04-06-2003, 11:28 AM   #66
ford50forlife
same here, the video isnt a video its just shows still pics at times...
Old 04-06-2003, 11:35 AM   #67
MAXIMA95SE
no your just ignorant to the fact that a cobra got his ass handed to him... that video is legit, say what you want theres no need to edit it to make it seem like maximas are faster.... Take your run with turbomaxima and video it I wanna see the outcome in the end..
Old 04-06-2003, 11:36 AM   #68
the vid worked for me..
It maybe cause of your connection speed.. Try to save as, if you havent already tried it..
Accord Man is offline
Old 04-06-2003, 11:36 AM   #69
ford50forlife
with enough money anything can be made to go fast im not impressed with some fool spending 10 g's to make a semi fast car, thats pathetic.....
theres a suzuki swift 1.3L around here that does 11's on street tires, now THATS impressive
Old 04-06-2003, 11:39 AM   #70
ford50forlife
thats just ****ing retarded, and yes i will run him, and itll be a 15 year old motor vs. a newage dohc with turbo.... dead stop @ 25 light with my m/t's on the back.... dont matter if i win or lose, its the fact my whole car is still under 4 grand total and still sports stock cam, and stock heads and no forced induction.... look forward to the outcome myself.
Old 04-06-2003, 11:43 AM   #71
MAXIMA95SE
thats just ****ing retarded, and yes i will run him, and itll be a 15 year old motor vs. a newage dohc with turbo.... dead stop @ 25 light with my m/t's on the back.... dont matter if i win or lose, its the fact my whole car is still under 4 grand total and still sports stock cam, and stock heads.... look forward to the outcome myself.
its not that we are bashing on your car or anything its just that were a 4 door family sedan with power to go along with it, some of us might like that luxery feel WITH the motor power to go with it.. While you like a 2 door coupe thats MORE sporty looking with the power to go along as well.. Its just different taste... Anyways that being said heres one more video...
http://www.vqpower.com/v2/modules.ph...p=getit&lid=56
Old 04-06-2003, 11:49 AM   #72
ford50forlife
well you get what you pay for..... and sorry to burst your bubble but i want speed and for 3500dollars as of now im happy with 105mph traps in which my motor is actually DETUNED from stock...
and if i wanted 4 door performance i wouldnt look to a maxima at all
id go with a dodge spirit r/t
ever heard of a 4 cylinder 4 door sedan dynoing more tq than hp from boltons? 220whp and 310wtq from simple upgrades. not to mention the 2.2L chrysler turbo motor doesnt need to be introduced
Old 04-06-2003, 11:52 AM   #73
ford50forlife
haha 15.4@65 either thats a hella fast 4 cylinder or somebody let off...
Old 04-06-2003, 11:52 AM   #74
MAXIMA95SE
you got your opionions we got ours, we respect yours hopefully you respect ours.. Nuff Said
Old 04-06-2003, 01:08 PM   #75
It worked, but it was just real dark. Time to upgrade the digi-cam
Addict is offline
Old 04-06-2003, 07:19 PM   #76
HondaTypeJ
Rofl. When I came to this forum and saw this old thread that I posted ages ago, I was like WTF? Kewl. That was a loooooooooong time ago.
Old 04-07-2003, 02:32 PM   #77
SilverCiv
No way could a GSR beat a MAXIMA. He must have been a TERRIBLE drive or not trying. If it was driving, then congrats.
Old 04-07-2003, 06:06 PM   #78
bk2kmax
You know it's a damn shame when you try to bs someone and the guys on your own forum that drive the same car raise the BS Flag on you. Thank you guys for not being too proud to admit that there is no way in freaking hell he did what he said.
Threads/Post like his should be moderated or at least screened well before they even are allowed to be posted this way you won't have everyone arguing and flaming one another for somebody's fantasy.
Old 04-07-2003, 06:32 PM   #79
Originally posted by bk2kmax
You know it's a damn shame when you try to bs someone and the guys on your own forum that drive the same car raise the BS Flag on you. ...
SilverCiv drives a Civic, not an Integra.
Addict is offline
Old 04-07-2003, 06:33 PM   #80
ford50forlife
you know its a damn shame when someone joins a forum to comment about a thread that downplayed the car they drive..
Closed Thread
