Old 05-14-2006, 07:53 AM   #41
Originally Posted by sicones
nice, I like those wheels I wish they were bigger tho like 15", those are some beefy ass tires
Eh. They're nice & light. The rims themselves only weigh 11.9lbs. That was my reasoning behind getting them. That & I needed new tires anyhow.
Originally Posted by nonovurbizniz
If I ever decided to pick up another honda it'd be that gen 4 door and put a h22 in it.
I always like the 4 doors from that year for some reason...
Nice pick up though and with just the couple things you bought you should be pretty satisfied for a LITTLE bit at least...
It's hard giving up dumping money into cars even when you say that it's "just my daily driver"... I almost went nuts and started buying stuff for the subaru but managed to control myself.
Yeah its real tough to not do much to it. I keep catchin myself searchin H-T classifieds and ebay.
I have a B18 lined up already (for free). So yeah, its likely to get a change.
Originally Posted by KwikR6
Oh Snap Addict. Those are super nice.
Pics of them on the car.
or ban.
lol.... I didn't have time to get them on the car yesterday. I will this week though.
Old 05-14-2006, 12:19 PM   #42
Sweet deal mang.
Old 05-21-2006, 08:36 PM   #43
So I started on the rust repair on the driver's side yesterday. Basically just trying to stop the rust that's there now. So cutting and sanding. Still have a ways to go.
What it looked before the dremel got a hold of it:
After the dremel ate it:
And I finally got the HX wheels on. I had to use a lot of PB Blaster on one of the wheels (and a hammer). I did take pics but I forgot my camera (not home now). So I'll post those up tomorrow.
Old 05-21-2006, 09:26 PM   #44
Rust repair. ICK!
Old 05-23-2006, 08:50 AM   #45
Got the wheels on the car:
Old vs. New (that was the GOOD 13" wheel....lol)
Yeah it needs lowered. 4x4 action happenin' there.....
Old 05-23-2006, 02:51 PM   #46
Dude those bronze hx wheels are the tits. I like it.
Old 06-04-2006, 10:47 PM   #47
Long Post
More on the body work.....
So I decided to go the Bondo route for rust repair. Mostly because at this point I don't have a welder and I've never done fiberglass work before. The again I've never used Bondo either.
Here's what it started as:
After chopping the rust out:
I started prepping the rear driver's side section by sanding it down to bare metal with 60 grit (after I cut away the rust) sand paper. Let me say a couple things here:
1)3M SandBlaster sandpaper has to be the BEST sandpaper I've ever used. It lasts and doesn't clog. Worth the money.
2)Invest in a nice sanding block. I spent a lil extra change on a 3M block and its made this much easier. Nice & heavy, holds the paper very well and flexes (made of rubber).
Then I taped off the area with some 3M Scotch(you'll see this brand alot from me ) automotive painting tape (green stuff). Yes its different than the Scotch Blue Painter's tape. Its heavier and allows you to sand up to the tape without it ripping up. I also used a cheap drop cloth to cover the areas I didn't want to get paint/bondo on. The inside area got a thorough coating of rust convertor to help prevent the rust from coming back. Its like a primer so you have to sand it back off the outside area.
Sanded:
Mixing Bondo is a little hard to comprehend from the label. The instructions are one long run on sentence. Basically, use a about a 3" spot of filler that's 1/2" thick with a 1.25" strip of hardener. Mix thoroughly and work FAST as hell. This stuff sets up real quick. Only mix what you can work with in 3 minutes or less. Apply with a spatula/spreader. My thinking was its better to have a good buildup that I could sand down rather than a low area that I'd have to re-apply. Let sit for 30 minutes.
Fresh Bondo:
So after it set up I was back at it with the 60 grit. Its important to remember that you need to let the sandpaper do the work. In other words, don't press hard on the block. You want to work slowly to shape the Bondo correctly. Follow this with 120 grit and then 320 grit prior to primer. Pull the tape and remask off the area (clean paint lines).
The primer needs to be filler primer or etch primer. Chances are real good you'll have some pinholes. No worries though. The primer should fill anything up to 1/16" deep. Wipe the area down with some tack cloth (a MUST) to remove any dust. Apply the primer according to what the can says. Light coats work best.
Primed:
So that's where it is right now. I still have to take some 600 grit to the primer to finish it up. But that's tomorrow's project.
Old 06-04-2006, 11:05 PM   #48
GT40FIED
Best...mod...ever
Bondo can be fun. Especially is you mix the entire containers of the puddy with the curing agent. Stand back and watch the fire!
Welcome to the new Amerika
Old 06-05-2006, 02:39 PM   #49
hahahahaha
Addict. I love this build up thread
Old 06-05-2006, 10:37 PM   #50
awesome. get some smaller tires..
Old 06-06-2006, 07:28 AM   #51
No way. That's part of teh D15 non-vtac sleepa look! Besides they have too much tread left to justify getting rid of em.
Old 06-06-2006, 10:13 PM   #52
ahh good point.
j-yard turbo set up D15 with a D16 head swap.
Old 06-07-2006, 07:42 AM   #53
ahh good point.
Already have something with the letter B on it....
Old 06-08-2006, 12:16 AM   #54
B18B?
I have a feeling
Your bum sags I just realized.
Old 06-08-2006, 07:42 AM   #55
[quote=KwikR6]B18B?{/quote]
Could be....
I have a feeling
You Canadians and your crazy sayings....
Old 06-08-2006, 06:23 PM   #56
[quote=Addict]
B18B?{/quote]
Could be....
take that for a saggy bum
Old 07-03-2006, 09:53 PM   #57
Well "tomorrow's project" turned into next month's project.
Anyhow. More body work. Started on the other cancerous region. Front of the driver's side rear fenderwell (follow that?).
How it started:
After some cutting & sanding:
I cleaned it up quite a bit after that pic. That's not rust you see.
Bondo'd (& spot putty'd):
It got sanded more after that pic....
Primered:
Look ma! No hole!
To those who think bondo is evil.... You just have to remember to reinforce it. There's metal mesh behind that bondo to help with the strength.
And one last pic:
Can you believe that ish? Now this car really has to go!!
Old 07-03-2006, 11:45 PM   #58
You really hate Canadians don't you haahah
Were not all bad. That's like classifying all Americans as retarded. And clearly there's a few on here that aren't....the rest are hahahahahah
Old 07-03-2006, 11:47 PM   #59
Nah. I just like giving you all a hard time.
Old 07-04-2006, 12:50 AM   #60
Oh I know...i think hahaha I'm just playing around also
